About these Front Springs ??
Old Sep 16, 2010 | 10:33 AM
Clams Canino's Avatar
Clams Canino
Default About these Front Springs ??
OK... I have the front control ("A") arms back in the car and am trying to install the front springs. I'm using these replacement springs that came in my "Zip Kit" last year.
http://www.zip-corvette.com/ProductD...GR-SR&CTitle=&
Despite them being shorter... I'm having problem getting them in there.
It's an "angle issue" I'm having. If I seat them correctly in the lower arm - they don't want to fit into the upper tower hole correcty. They sit "cocked" and don't go up in there all the way.
So what did you all do? Any other comments on these particular springs?
-W
Old Sep 16, 2010 | 10:58 AM
wcsinx's Avatar
wcsinx
I used the same springs. They're actually quite a bit easier to install than stockers.
Yeah, it can be a little tricky. I like to get the hub mounted to the top a-arm and just let it dangle. Then I get the spring seated in the bottom arm and jack it up little by little. Sometimes they'll pop into place on their own once the spring flattens a little. If not, then a good solid kick (literally a kick w/ your foot) inwards on the spring will get it seated in the upper pocket. I'll go one pump on the jack and then a kick and then repeat. Then once the lower arm is high enough to swing the hub ear beneath the ball joint bolt, you're there!
Old Sep 16, 2010 | 12:06 PM
Zip Corvettes's Avatar
Zip Corvettes
Platinum Supporting Vendor
Are you using a spring compressor? You need to compress the spring so that it is collapsed and you can get both ends of the spring in the pockets. It is the same as installing the stock spring except this one is shorter so there is less chance of it popping loose and doing damage.
Justin
Old Sep 16, 2010 | 12:59 PM
72LS1Vette's Avatar
72LS1Vette
The 550# springs need very little compression to get the threads on the upper ball joint started. I used a crowbar to nudge the spring over as the lower arm was raised. The spring should then go into the upper pocket without much trouble. I put a screwdriver into the upper inspection hole and butted the end of the spring against it to align it. You have to adjust the jack pressure to get the spring just loose enough to rotate.
Rick B.
Old Sep 16, 2010 | 03:10 PM
Clams Canino
Thanks all for the replies. Feel free to keep discussing springs...
-W
Old Sep 16, 2010 | 03:14 PM
Clams Canino
I thought most people aligned the spring to the lower inspection / drain hole - and let the upper hit where it will?
My spring and both upper and lower pockets are painted - therefore rotation might not come as easy.
-W
Old Sep 16, 2010 | 03:39 PM
72-LT1's Avatar
72-LT1
I agree, I put them in and jacked up a little and just kicked it a few times to seat them. Then I just twisted by hand to seat them in the inspection hole.
Old Sep 16, 2010 | 05:10 PM
72LS1Vette's Avatar
72LS1Vette
-W
The Assembly Manual describes aligning the spring with the upper inspection hole. It doesn't say anything about the lower hole. With aftermarket springs the chances of getting both holes to line up is unlikely anyway.
Rick B.
Old Sep 16, 2010 | 05:49 PM
wcsinx's Avatar
wcsinx
-W
They should both be fairly close. My spring ends were about half an inch from both the top and bottom holes.
To About these Front Springs ??
