Brake Rotor Shims
I've never shimmed a rotor before but I'm thinking a .003 inch tapered shim would get the runout within spec. Of course, if the shim is intended to only give .003 inch at the edge, I'm not even close and even the .009 inch shim won't do the job. The video also tells me not to use more than one shim and never re-use a shim. At $20 a shim, this could get expensive real quick.
Make sure the brake lathe they have is in top condition and make sure they just take a minimum cut.
If doing the rears, almost the same thing, mount the new rotors to the hubs with the socket head bolts and find a shop that has an "on car lathe". It's pretty common these days since most newer cars have removeable rotors (with the same problems) and there are plenty of shops in Broward and Palm Beach with the lathes.
The front wheel drive rotor will not try to wobble side to side (due to the bearing design), there is no way you can keep the Corvette rotor in check when the wheel is off the ground unless you have dialed the bearings down to .000 end play.
Bob , IMO shimming is much safer and in "your"control and the tapered shims are the best because they support the entire hub face. I do wish the tapered shims were cheaper and came in smaller increments. I would love to find a supplier for tapered shim material so I could have the shims made.
If bearing play exists in the rears, no amount of shimming will cure runnout anyway.
The good machines are mounted in place of the rim, absolutely no rotor movement, same as having your wheels mounted, so bearing play doesn't come in to it at all anyway.
Supposedly vtech does good work, so nothing should be needed on your rears.
I'll try and get you a couple of names when I get a chance. A lot of places closed up around here in this economy.
That may be a while. Car is disassembled at the moment. Would have to bring the on-car lathe to my house and I doubt anyone's gonna do that for what I'd expect to pay.
Mike, I have a couple of friends who do that for me. I'm a drunk who quit drinking six or seven years ago. Not an alcoholic 'cause I don't go to meetings.
1. Correct the runout with a shim.
2. Correct the runout with machinery.
3. Ignore the runout.
Option 3 is the cheapest but the risk is inadequate braking in an emergency (the whole reason for the post).
Option 2 is the most expensive and although it may correct the problem it is irrevrsible (once the rotor is cut I can't uncut it).
Option 1 looks like the middle of the road and I can fall back to either of the other two if it doesn't work.
Let me take an extreme example. If my hub has 1 inch of runout and I mount a new rotor on that hub, the rotor will have even more than one inch of runout at its edge. The wheel rim runout will be even more than the rotor edge and the tire more than the rim. Cutting half the runout from one side of the front of the rotor and the other half from the other side on the back would fix the rotor runout and the brake caliper burping but won't address the wheel/tire or original hub runout problem.
If I put a one-inch tapered shim on the hub and then install the rotor, there should be no runout at the edge of the rotor, rim or tire.
I know the rim is going to have its own intrinsic runout -- I just don't want to add to it.
Seems to me using a brake lathe to fix this problem is like shaving tires when they wear unevenly because of a suspension alignment problem.
I started this thread because the .005" runout on my driver side hub translated into slightly more than .015 runout at the rotor edge. The video from a company that sells the shims shows the measurement taken at the edge of the rotor being used to select the shim taper. Made no sense to me so I was trying to find out if the video was wrong or there was some formula for selecting the hub shim based on the rotor edge runout. I now believe the video is wrong but it's more likely me who's wrong (as my wife frequently reminds me).
I'll let you know if the shims fix the problem.
