402 big block
Old Sep 18, 2010 | 07:42 PM
troythefixer's Avatar
troythefixer
Default 402 big block
hello, a friend gave me a 402 big block, I'm not crazy about the small bore and the small displacement for a big block, does anyone know what the max bore is and what the displacement would be at max.........tks................Troy
Old Sep 18, 2010 | 08:46 PM
PuddleJumper's Avatar
PuddleJumper
not to sure,, if it can be stroked to 4 in 421cid, if you can bore it
stock bore 4 in stroek (454 crank) 421 cid,
bored .060 over, 4 in stroke (454 crank) 433cid
.060 over and stock crank 407.66 cid
so i would do a little home work because it might beable to take the longer stroke but im not to sure..
i might be able to handel more boring as well or less..
i dont know much about BBC's but that should give u some ideas
Old Sep 18, 2010 | 10:11 PM
troythefixer
tks for ur input, the research I have done in the past little while says not to waste time on a 396 or 402 because of small bore valve shrouding so I guess it I'm going to go big I'll look for a 454.TksTroy
Old Sep 18, 2010 | 10:29 PM
PuddleJumper
yeah i would go 454 myself, i would keep the 402 and see if it belongs to any "special" cars and see if a owner would want it to make his car correct.
advice from my uncle.. never toss a old "small displacment block" untill you sure its worthless.
where do you live? might be intrested if i cant finde a good SB
To 402 big block
