Will these fit?
Old Mar 30, 2002 | 09:17 PM
rainman69's Avatar
rainman69
Default Will these fit?
Will these rockers fit under the stock valve covers? I'm looking at the 1.52 ratio rockers.
Old Mar 30, 2002 | 09:30 PM
Armstrong's Avatar
Armstrong
Default Re: Will these fit? (rainman69)
I don't know but they sure do look sweet. Sorry.
Old Mar 30, 2002 | 10:28 PM
Noel Carboni's Avatar
Noel Carboni
Yes, you can get 'em under there. I have a set.
The only things that will give you a little trouble are:
1. You'll have to grind off the oil redirector tabs from the inside of the covers.
2. If you use locking nuts, such as the tall KoolNuts, you will need to use a "double" or very thick valve cover gasket. I have gaskets that are two layers of cork, one each glued to both sides of a center metal support.
Have fun!
-Noel
Old Mar 31, 2002 | 12:03 PM
shawn_cake's Avatar
shawn_cake
Yep they will fit. You'll need tall valve covers if you use a stud girdle (highly advisable).
:D :D
To Will these fit?
