AIR PUMP or NOT?
Mar 31, 2002 | 12:30 AM
AIR PUMP or NOT?
Should my 73 L48 have an air pump?
Mar 31, 2002 | 12:37 AM
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Re: AIR PUMP or NOT? (dollagreen)
Are you asking if it should have it "historically" or if it needs it to pass emissions?
Mar 31, 2002 | 12:44 AM
Re: AIR PUMP or NOT? (sharklover)
Yeah, if you wanna know whether it came with AIR originally, then the answer is yes.
-Pedro
Mar 31, 2002 | 02:20 AM
Yes, All 73 Vettes came with the A.I.R. system.
tom...
Mar 31, 2002 | 10:38 AM
Re: AIR PUMP or NOT? (Tom73)
Yeah, I was asking if it came with AIR? It has long since been removed...still passes WI emissions.
Mar 31, 2002 | 02:10 PM
Cruise-In V Veteran
Then you only need one if you want to be NCRS correct. I pulled mine off this year and plugged the manifolds when I installed true duals. It was just extra, unneeded weight.
Mar 31, 2002 | 04:05 PM
How difficult was it to remove (unscrew) the air injector pipes in the exhaust manifold? And what did you use to plug the holes?
Mar 31, 2002 | 08:46 PM
Hee Hee, the '73 already has true duals :D :D :jester
tom...
