Speedometer gear
Old Sep 23, 2010 | 05:11 PM
Johan74's Avatar
Johan74
Default Speedometer gear
I have the gearbox (4-speed) from my 69 on my workbench. I have found out that the speedometer driving gear is not fixed on the axle, i.e if the driven gear is removed you can stick your finger in and move the driving gear up and down on the axle and the speedometer will ofcourse not work. So, I need to fix this.
1) How is the gear supposed to be fixed on the axle?
2) What are the major steps in opening the gearbox to get access to the gear? I have no experience of this, is it a major job? Does somebody have a good reference on the net?
//Johan
Old Sep 23, 2010 | 08:11 PM
Goody's Avatar
Goody
Usually you just have to remove the tail shaft cover. There is a clip that retains it. Might be inside the tail shaft cover.
If I am wrong, I'm sure I'll get corrected.
Old Sep 25, 2010 | 10:15 AM
Johan74's Avatar
Johan74
Ok, but what do I need to do to remove the tail shaft cover? Just the 6 bolts? I was thinking since the reverse lever is there it would make it more complicated, but I guess I will find out...
Old Sep 25, 2010 | 02:20 PM
1969RAY's Avatar
1969RAY
2025 C2 of the Year ('63 and '67) Finalist - Unmodified
C2 of Year Finalist (appearance mods) 2019
Didn't see your thread, but have the same question. Did the tail piece come off with 6 bolts?
To Speedometer gear
