Another name that wire thread - 1970 4sp
Old Sep 28, 2010 | 12:53 AM
UBETRUN's Avatar
UBETRUN
Default Another name that wire thread - 1970 4sp
Got a few that don't connect to anything from a LL engine harness kit. Nice kit and only took an hour to replace Bubba's work. Looking for some help on these so I can get on to wiring the MSD box and distributor. Car is a NOM 496 with fixed Motion headlights and no options. Thanks!
Old Sep 28, 2010 | 01:33 AM
Solid LT1's Avatar
Solid LT1
Upper connectors are for TCS spark controls for emissions system and lower single black looks to be wiper motor body ground wire.
Old Sep 28, 2010 | 08:21 AM
...Roger...'s Avatar
...Roger...
I believe its all TCS wiring.
Old Sep 28, 2010 | 10:07 PM
UBETRUN's Avatar
UBETRUN
The colors on the bottom wire are the same as the wire going to the blower but the connectors are different. I tried to show it but the flash was too bright, this connector is similar to a temp sender.
Old Sep 28, 2010 | 10:28 PM
...Roger...
It looks like a black with pink stripe , same as the other black with pink that goes to the TCS relay in the background,relay also has a green and blue.
Old Sep 28, 2010 | 10:32 PM
arcticcatmatt's Avatar
arcticcatmatt
what is a LL kit?
Old Sep 29, 2010 | 01:14 AM
UBETRUN's Avatar
UBETRUN
I need to look at that a little closer, don't need any of the TCS stuff! Thank you.
Old Sep 29, 2010 | 01:15 AM
UBETRUN's Avatar
UBETRUN
Originally Posted by arcticcatmatt
what is a LL kit?
Lectric Limited wiring harness for the engine compartment
Old Sep 29, 2010 | 07:55 AM
...Roger...
That's what I was thinking also. Some of the TCS stuff is sell-able. $
To Another name that wire thread - 1970 4sp
