TH400 vs TH350
Old Sep 28, 2010 | 10:29 PM
RBRUTLEDGE's Avatar
RBRUTLEDGE
Default TH400 vs TH350
Hello all!
I bought a 71 from my uncle and he had a TH400 in it with a shift kit. He also gave me the TH350 it came with. After reading several threads I see that many of you say the TH400 takes HP away from the performance. I have gone through everything from the suspension to the engine and drive train except for the tranny. It doesnt feel right to me so I am going to have it reworked at a shop. My question is would I be better off reworking the TH350 or the TH400? I am running a 383 stroker, a 750 Speed Demon Carb and 290 gears in the rear end. I have already spun the drive shaft so I bought a heavier one from Ecklers.
Any ideas would be appreciated!
Old Sep 29, 2010 | 01:00 AM
Grumpy 427's Avatar
Grumpy 427
The 400 has a 2.45 ist gear and the 350 has a 2.54 ist gear. I built a th 350 to handle 600 hp, the th400 is pretty much bullet proof out of the box. I would leave the TH400 in the car less hassle down the road.Plus its a factory piece so it all fits correctly.
Old Sep 29, 2010 | 03:00 AM
Tumarr's Avatar
Tumarr
I vote for keeping the th400, Its a very tuff trans, and I dont think it effects your performance that much.
Old Sep 30, 2010 | 08:01 AM
RBRUTLEDGE's Avatar
RBRUTLEDGE
thanks fellows
Old Sep 30, 2010 | 11:32 AM
cmjohn's Avatar
cmjohn
8th Gear
Definitly the 400!
Old Sep 30, 2010 | 11:35 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
For 68 and 69, you could order the L-88 with a TH400 behind it.
Old Sep 30, 2010 | 01:21 PM
ajrothm's Avatar
ajrothm
T400 is 2.48 1st gear, T350 is 2.52 1st. T400 definetly eats some power but is a direct fit, your electric kick down will still work and you can use your regular front slip yoke. Not to mention it's much tougher.
Keep the T400, basic rebuild with good clutches, 34 element sprag and Trans Go shift kit and you're good to go 10s.
To TH400 vs TH350
