clutch noise
Old Sep 29, 2010 | 11:12 AM
zekie's Avatar
zekie
Default clutch noise
hi. all
i have 81 vette 4 sp like 15 yr ago i replace the clutch if not mistaking it was a zoom clutch,pressure plate,bearing.after less than a month i had a little fender bender the car sat indoor until this yr car was not been driven, so i fix the car i started hearing a whining noise when the clutch was not engaged so i replace the bearing but i still hear the whining noise what could that be thanks to all for your help
Old Sep 29, 2010 | 03:36 PM
Paul Ruggeri's Avatar
0Paul Ruggeri
Former Vendor
Probably a bearing noise in the trans. Check the fluid level.
Old Sep 30, 2010 | 07:24 AM
zekie's Avatar
zekie
hi paul.
the fluid level is ok, but the noise only happen when the clutch is not enaged
Old Sep 30, 2010 | 11:27 AM
0Paul Ruggeri
Former Vendor
When you say not engaged, do you mean clutch pedal up or down?
Old Sep 30, 2010 | 09:42 PM
zekie's Avatar
zekie
in the down position
Old Oct 1, 2010 | 03:17 AM
OzzyTom's Avatar
OzzyTom
The gearbox input shaft spins in the pilot bearing when you depress the clutch. When you release the clutch, the clutch engages the flywheel and rotates the entire pressure plate and drives the gearbox input shaft, so it rotates at same speed as crank.
If your noise occurs when the clutch pedal is depressed, then it's the pilot bearing or gearbox shaft.
How bad was the fender bender?
Would it have been enough to cause any misalignment of trans to motor??? ie possible bent shaft or broken mounting bolts?
Otherwise I'd suspect a worn pilot bearing (bush)
Old Oct 1, 2010 | 06:23 AM
skaping's Avatar
skaping
Did you replace the release bearing, the pilot bearing, or both? If you just replaced the release bearing it probably needs a pilot bearing. One other possibility... if your engine has a lot of miles on it you could have a worn thrust bearing allowing a lot of movement of the crankshaft causing the noise.
Old Oct 1, 2010 | 01:22 PM
zekie's Avatar
zekie
i'm not sure if i replace the pilot bearing i also need to check my trans mount bolts.
the fender bender was minimal no structural damage thank all for the input i'll kept you posted
Old Oct 1, 2010 | 04:41 PM
0Paul Ruggeri
Former Vendor
Usually if the noise is when the pedal is down its the throw out bearing. That's when you're loading that bearing.
Old Oct 3, 2010 | 02:45 PM
zekie's Avatar
zekie
no the noise is when it off the pedal
To clutch noise
