81 vette
Old Sep 29, 2010 | 08:59 PM
stocker7489's Avatar
stocker7489
Default 81 vette
power steering control valve has no leaks .has alot of steering play.is there a repair kit available to take out the play.all other suspenion compontents are tight.major play in steering control valve at pitman arm with engine running or not.
Old Sep 30, 2010 | 09:05 AM
Tom@Zip's Avatar
Tom@Zip
Platinum Supporting Vendor
1981 Control Valve Components
Here are some options to clear up that play in the control valve.
If you have any questions, feel free to give me a call.
Tom, 1-800-962-9632 ext 240
__________________
Zip Corvette Parts and Accessories - Corvettes Are All We Do!
Selling Quality Corvette Parts & Accessories Since 1977
Corvette Parts Catalogs | Subscribe to our newsletter
Corvette Tech Articles | Corvette Parts Blog
Old Sep 30, 2010 | 11:11 AM
Paul Ruggeri's Avatar
0Paul Ruggeri
Former Vendor
Rebuilt ones aren't too expensive, so I'd just replace it.
Old Sep 30, 2010 | 11:28 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Could be the steering box and not the valve. Have you taken the lash out of the box?
Old Oct 1, 2010 | 11:40 AM
LS4 PILOT's Avatar
LS4 PILOT
My 74 had worn that pivot joint out on the valve. It can be repaired , but all the trouble to take the valve out , might as well just replace it as it was original to the car. I had no other suspension issues either. I have new frt springs ( best money I every spent) and new GM shocks. It handles probally 95% now good as new . No slop or play.
I did for good measure for my car , oh maybe 8 years ago sent my steering box off to BAIRS COrvettes in PA , wasn't very expensive and was pretty easy to take in and out myself. and they rebuilt it and I replaced the rag joint. They do good work.
Old Oct 1, 2010 | 11:07 PM
dburgjohn's Avatar
dburgjohn
was the car running when you checked for slack? I thought mine had slack because it moved with car off. Others here enlightened me to the fact that pump pressure holds it tighter.
To 81 vette
