Alternator bracket for 1968 327?
Old Oct 1, 2010 | 10:24 AM
cmjohn's Avatar
cmjohn
8th Gear
Default Alternator bracket for 1968 327?
Does anyone make an alternator bracket for the use with double hump heads?
Old Oct 1, 2010 | 10:53 AM
Garys 68's Avatar
Garys 68
The 68 SBC alternator was mounted to the drivers side ramshorn exhaust manifold.
If you are not running the ramshorn, check Summit for aftermarket mounts for headers. They sell a bracket that mounts to the exhaust manifold bolts.
Old Oct 1, 2010 | 12:09 PM
markdtn's Avatar
markdtn
all 68 (and older) SB heads do not have accessory holes.
Old Oct 1, 2010 | 02:37 PM
cmjohn's Avatar
cmjohn
8th Gear
Thanks guys. I found what I need at Summit and the price is pretty cheap.
Old Oct 1, 2010 | 02:44 PM
cmjohn's Avatar
cmjohn
8th Gear
Ok, now. Since I'm going to put an eletric water pump on it and not running a power steering pump , how long of belt do I need to run from the alternator to the crank pulley?
To Alternator bracket for 1968 327?
