1972 ls5 vented gas?
Old Oct 1, 2010 | 10:29 AM
MEAN72's Avatar
MEAN72
Default 1972 ls5 vented gas?
Does a 1972 LS5 require a vented or non-vented gas tank?
What is the difference between the two systems beside the cap on the gas tank?
Old Oct 1, 2010 | 12:08 PM
Mashman's Avatar
Mashman
I believe the non-vented cap is for emmisions control. The non vented cap would contain the gas fumes so that they could be sucked into the vapor canistor, and then sucked into the carb and burnt off the next time the car was run.
So, I think if your car has a vapor canistor, and it's operational, then you should have a non-vented cap. Many people have disabled the vapor canistor by blocking the lines, and switching to a vented cap. If the system isn't sucking out the fumes, and releasing the pressure in the tank, you need to use a vented cap.
Old Oct 1, 2010 | 12:11 PM
markdtn's Avatar
markdtn
Yep, no canister use a vented cap. If you have the whole vapor control system, use a non-vented cap.
Old Oct 1, 2010 | 02:17 PM
MEAN72's Avatar
MEAN72
Default vapor canistor
Thanks guys. I don't think I have a vapor canister. Where would I find it? When did they introduce the vapor canister?
Old Oct 1, 2010 | 04:04 PM
Mashman's Avatar
Mashman
Not sure when they were introduced, 70 or 71??? But, all 72's should have them. The vapor canistor should be behind the drivers side louvre. It should have 2 lines from the carb, a larger one that is also connected to the PCV valve, and another smaller one connected to a vacuum port on the carb. There is a third line that connects to the canister from the fuel seperator on the gas tank.
Old Oct 1, 2010 | 04:43 PM
MEAN72's Avatar
MEAN72
Thanks Mashman. I do have the vapor control system. What I also have is the wrong (vented) gas cap. I need to correct that.
To 1972 ls5 vented gas?
