Headlight system
Old Apr 1, 2002 | 02:03 AM
jerryjfunk's Avatar
jerryjfunk
Default Headlight system
Hi guys...
Does anyone know where to find information on the headlight systems in a 79' Vette?? I can't find anything, even the repair manual doesn't cover it. Any help would be appreciated...
They don't move, and a lot of the vaccum hoses in the engine compartment have been messed with it looks like. I guess I need a diagram of the routing, and anything else that would help.
Thanks,
Jerry
Old Apr 1, 2002 | 03:17 AM
IronJen's Avatar
IronJen
Abby Normal
Veteran: Marine Corps
Default Re: Headlight system (jerryjfunk)
jerry, there is a wealth of information here. don't really know where to point you for advice except the factory service manual or just tell us what the problem is and see who else has had the same problem.
Old Apr 1, 2002 | 04:48 AM
twotone82's Avatar
twotone82
Hi Jerry,
I don't know if this will help much, but I've attached a scan from my '82 GM shop manual. It's a little hard to read, but I hope it helps a bit.
Good luck.
Old Apr 2, 2002 | 12:12 AM
jerryjfunk's Avatar
jerryjfunk
Default Re: Headlight system (twotone82)
Thanks, that does help me; now I can attempt to put all the hoses in the right places, and go from there. I wish mine were color coded though... lol.
Are there any components of the system that commonly go bad on these?
Thanks,
Jerry
Old Apr 2, 2002 | 01:41 AM
Chris O''s Avatar
Chris O'
You could also try http://vetteworks.tripod.com./techdocuments/Vaccum.html
Old Apr 2, 2002 | 01:16 PM
IronJen's Avatar
IronJen
Abby Normal
the most common problems with the headlight system is the check valve located in the hose from the manifold (between carb and distributor), the vacuum relays and the seals on the actuator canisters.
Old Apr 7, 2002 | 05:39 AM
twotone82's Avatar
twotone82
Jerry,
Just a thought. If your headlights don't move, check your T connectors from the vacuum relays. I had a "lazy" driver's side light (it tended to go up when the lights weren't on or it wouldn't close.) My problem was a crack in the T connector. They tend to dry-up and crack over the years. I couldn't see a crack in it, but as soon as I replaced it, my headlight(s) were fine. 2 bucks for a set of 4 from NAPA.
Also, check the actuator seal(s) (Witches' Hat).
Old Apr 7, 2002 | 01:05 PM
Sean Willard's Avatar
Sean Willard
If you do have to rebuild or replace components for your system Zip has the parts you need on sale right now, I just ordered mine yesterday. Looking forward to proper functioning light! :D
http://store.yahoo.com/zipproducts/h...omponents.html
:cheers:
Old Apr 7, 2002 | 10:46 PM
stingray72's Avatar
stingray72
Default Re: Headlight system (Sean Willard)
Try this link.
http://www.docrebuild.com/dr-r-web/A-VHT-POSTER.HTML
If you want the headlights to go up and down after you install the hoses, better get one of these diagrams.
George
Old Apr 7, 2002 | 10:51 PM
joeveto's Avatar
joeveto
Cruise-In IV Veteran
Cruise-In V Veteran
St. Jude Contributor
I believe I found everything I needed on CorvetteFaq.com. There is an entire section on headlight vacuum system repair, along with vacuum hose diagrams.
I hope this helps.
To Headlight system
