to increase track width with oem rims:spacers?adapters?
Old Oct 3, 2010 | 03:07 AM
elle88's Avatar
elle88
Default to increase track width with oem rims:spacers?adapters?
I would like to increase the track width about 1" per wheel but keeping my 15" rims. the car have to go on a racetrack. heard not good things about wheel spacers and instead wheel adapters suggested.
would this fit on oem rims too?
http://www.vbandp.com/Wheel-Adapters...ters-Pair.html
Old Oct 3, 2010 | 09:13 PM
vettehardt's Avatar
vettehardt
Yes, spacers would not be a good idea. Those adapters would work with your 15" wheels. You might have to cut down your studs a little or clearance out the back of your wheels so the wheels will sit flush on the adapters. I've been using 3" adapters with 84-86 16" wheels on my autocross car for about 12 years now with no problems.
Old Oct 3, 2010 | 09:15 PM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
If possible, and relevant rules aren't otherwise available, I'd try to inquire of the safety techs ahead of time what they find acceptable so you don't show up ready to have a go only to be turned away. Different tracks and organiziations have varying standards, but there may likey be specific requirements about wheel attachment, especially regarding the use of spacers or adapters (if not prohibited altogether). IMCO, this is more critical on a road course, so I'd be surprised if they didn't have anything to say on the subject.
Old Oct 4, 2010 | 08:16 AM
gkull's Avatar
gkull
Not all adapters are created equal. I have raced my 2 inch adapters for 10 years. Mine were offered in a variety of stud options. I have the stock 7/16th spindle studs with 1/2 wheel studs. You could also get 1/2 and 1/2 studs, but I elected to keep my spindles back then.
When you bolt the adapter to the spindle and Tq it to 85 pounds the adapter aluminum creates a strong mechanical bond. A few years ago when I replaced my outer spindled I had a heck of a time getting the adapters off.
So anyway 4 different types of race techs have looked at my set up.
NHRA, SCCA, NASA, speedventures
Old Oct 4, 2010 | 10:09 AM
redvetracr's Avatar
redvetracr
and you know this why?
1/2" studs with 5/8" spacers for 11 years on the #1 below.
Old Oct 4, 2010 | 10:42 AM
elle88's Avatar
elle88
I've been at the racetrack on saturnday ( not with the Vette but with my Porsche) and no controls at all on the cars... I think I can use whatever i like.
I don't like the idea of cutting my spindles studs to have them flush with the adapter...and btw in Italy wheel spacers are widely used without issues...possibly just a matter of keep them tight and check ,retorque often.
since i need just 1" or less spacing, possibly spacer and longer studs are not that bad. btw , who sells them ? Summit for spacers and studs? who sells wheels adapters instead?VB&P has just 1 wheel adaptor and a poor quality picture
Old Oct 4, 2010 | 03:47 PM
81_vette!'s Avatar
81_vette!
Default I love wheel adapters.
I put 1" adapters (not spacers) on the rear of every C3 I ever owned with no issues.
The 1" adapter (no pattern conversion) will cover the existing studs with no modifications required. These come with open ended lug nuts, too. Direct bolt on.
I like the ones these guys make:
http://www.ezaccessory.com/Wheel_Ada...5475-5475k.htm
Old Oct 5, 2010 | 12:57 AM
elle88's Avatar
elle88
Thanks for the link. it looks like exhactly what i'm searching for.
just 1 question : what about the wheel centering onto the hub? just bolt on everything and the wheel+adapter+hub are correctly aligned? or possible issues with a slightly off-axis and so vibration at speed?I'm new to the thing
Old Oct 5, 2010 | 07:52 AM
81_vette!'s Avatar
81_vette!
All you have to do is bolt em' on and your ready to go. The open-ended lug nuts are acorn shaped so they center the adapter nicely. And when you bolt on the wheel, just softly tighten each lug nut and this will help center the wheel, then you can tighten the wheel down. No wobble or vibration issues.
These guys ship fast, so you usually get the adapters in about 3 days. Very nice quality.
Here is a pic with their 1" wheel adapters on a 1977 with aftermarket wheels.
Old Oct 5, 2010 | 07:02 PM
vettehardt's Avatar
vettehardt
VBP does sell more spacers. I don't know why they aren't showing them on their website. They sell anything from the 3/4" you are looking at up to 3" that I currentlly run on my cars. They also sell ones to change your lug spacing if you wanted to. Like say change to 4.5" or 5" lug spacing. If you call themup I am sure they would help you out.
What I was trying to get at above is that a 3/4" or 1" spacer is a bad idea especially if you don't change out to longer and even larger studs. I have run up to a 1/2" spacer on stock studs, but the lugs I was using at that time had a shank on them that went inside the wheel so there were more threads engaged inside the lug.
And since we are posting pictues of cars with adapters, here is mine. 16X9.5" C4 wheels with 3" VBP adapters on all 4 corners:
My 73
My 76
Old Oct 6, 2010 | 12:44 AM
gkull's Avatar
gkull
You have two wheels on the wrong side of the car. The wheels should have the vains as they roll pulling air across the rotors and out.
My 76
Old Oct 6, 2010 | 02:11 PM
69427's Avatar
69427
From: I tend to be leery of any guy who doesn't own a chainsaw or a handgun.
My 76
I disagree. I believe they'll pull more air out of the discs if they're placed in the way Dave has them (on the rear) above. Remember, Chevrolet put them on the other way because, as Dave McClellan said, the styling group thought it looked "aggressive" that way. Frankly, I think it looks *** backwards their way.
When I run C4 wheels on my '69 I swap them around for the two reasons I've stated.
Old Oct 6, 2010 | 02:27 PM
gkull's Avatar
gkull
Then they should all 4 be the same direction, not two one way and two the other. They were designed to pull the air out from under the car across the rotors and out.
Old Oct 6, 2010 | 03:27 PM
69427's Avatar
69427
I agree that they should all be the same direction. But as I said, they were designed (or more correctly, styled!) to look aggresive, and functionality was not a factor. This is just one more instance where McClellan let the Styling Group walk all over him, and he dropped the ball, engineering wise.
To to increase track width with oem rims:spacers?adapters?
