What is the thread count on a Quadrajet? i need a fitting to go from the QJ to a 6 An fitting. i would think the QJ is an inverted flare fitting as well.
Far as I know, all the fittings are 20 tpi. but be careful. Some inlets are 1-inch and others are 7/8-inch. Double-check before you order.
I ordered the fuel line kit from Summit, which says it's for "Quadrajet carburetors (up to and including 1974) with a 7/8-20 in. carburetor inlet." http://www.summitracing.com/parts/SUM-G3150/
