need a 76 vacuum diagram
Old Oct 5, 2010 | 06:49 PM
mj9311's Avatar
mj9311
Default need a 76 vacuum diagram
is there anywhere or any one i can get a full vacuum diagram from??
Old Oct 5, 2010 | 06:56 PM
...Roger...'s Avatar
...Roger...
Willcox will have one.
Old Oct 5, 2010 | 07:22 PM
Peterbuilt's Avatar
Peterbuilt
Do you need the heater side too?
Old Oct 5, 2010 | 07:27 PM
mj9311's Avatar
mj9311
no thanks i have no heat in it. but is there a vacuum canister stock?? there seems to be one mounted on the driver side frame below the steering column or is that something else
you can kinda see it here under the washer tank
Old Oct 5, 2010 | 07:42 PM
Peterbuilt's Avatar
Peterbuilt
Down there is the VAPOR canister, that's for gas fumes.
The VACUUM tank is a big round tube in the front of the motor, the tank should have 3 ports.
Old Oct 5, 2010 | 07:54 PM
mj9311's Avatar
mj9311
yes im aware of the big one in the front just curious as to what that was. it was not connected to anything when i pulled my motor is it needed when i reinstall the motor?
Old Oct 5, 2010 | 08:46 PM
...Roger...
Depending on what your doing with the car you can get rid of a lot of stuff.
The vapor canister on the 76 if I remember right is dual purpose.
It collects fuel vapors from the carb after the engine is shut off and vents the fuel tank.
You can "get by" with a vented gas cap.
To need a 76 vacuum diagram
