Fuel pressure
Old Oct 7, 2010 | 08:02 PM
Dr L-88's Avatar
Dr L-88
2025 Corvette of the Year Winner- Modified
2024 C2 of the Year Winner - Modified
2022 Corvette of the Year Finalist -- Modified
2021 C2 of the Year Winner - Modified
2021 C1 of the Year Winner - Modified
2020 Corvette of the Year (stock)
C2 of Year Winner (stock) 2019
2017 C1 of the Year Finalist
Default Fuel pressure
What is the proper fuel pressure for a carbureted big block Chevy street engine (pressure at the carb)? System has a Holley electric fuel pump, 750 carb, in-line adjustable regulator and a pressure gauge, newly installed, reads 11 psi with pump on and engine off. I adjusted the regulator to lower the pressure but to no avail. Does engine have to be running when adjustments are made?
Old Oct 8, 2010 | 09:22 PM
vetteguy75's Avatar
vetteguy75
LA Events Coordinator
I have a Holley 670 Street Avenger and the fuel pressure I'm running is 6lbs. I have a fuel pressure gauge.
Old Oct 9, 2010 | 01:24 AM
UBETRUN's Avatar
UBETRUN
You set fuel pressure with flow at idle, either through the carb while the engine is running or through a flow gauge that simulates a carb. If your carb is in good condition, anything under 9psi shouldn't overflow the bowls and above 4.5psi is enough to keep the motor fed.
11psi is too high but until you get flow through the regulator, you won't have a truly accurate measurement.
To Fuel pressure
