Front springs
Old Oct 12, 2010 | 07:37 AM
Sho'nuff's Avatar
Sho'nuff
Default Front springs
Are there any springs i can use to drop my front end anout 3 inches and still ride decent?
Old Oct 12, 2010 | 09:25 AM
bashcraft's Avatar
bashcraft
Depends on which springs you have now.
Old Oct 12, 2010 | 12:26 PM
thegazman's Avatar
thegazman
Default thegazman
Speed Direct has an article on their web site of how to properly cut your front coil springs, but 3 inches is a lot and will probably give you a miserable ride.
Old Oct 12, 2010 | 05:15 PM
FKING1's Avatar
FKING1
3" seems a bit much. Ride will be hard. Lowered my 70 2" and any more could rub.
Old Oct 13, 2010 | 02:55 AM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
Default BTDT, bought and wore out the T-shirt...
3" lower from where, OEM heights? If so you'd almost certainly have to cut any available springs down a good bit to go that far, and will very likely need somewhat stiffer springs than stock ones (even with the increased spring rates due to shortening them) to reduce excessive bottoming, which would yield still less comfort.
IMOE, whether for apperances or performance, slamming very much beyond Chevy's road race prep recommendations results in rapidly diminishing returns and increasing penalties (including bashed oil pans). Also, while some rake may be desirable, one can go too far and end up with some rather odd handling characteristics. Not telling you what to do, just trying to make sure you know something of how deep these waters can be before you simply dive in.
FWIW, after learning the hard way and getting some expert C3 handling advise from Mr. Guldstrand, I've long been at Chevy's RR specs, and on fairly stiff Daytona coils. Yes, it rides what many backsides would likely consider as harsh, but comfort isn't exactly my first priority.
Old Oct 13, 2010 | 07:59 AM
73jst4fun's Avatar
73jst4fun
Good advise, 3" is too low and the after affects in the long run will cost you $$$. There's plenty of aftermarket components from vendors here/VBP for one that sell kits that are adjustable for ride hieght...
Old Oct 13, 2010 | 08:37 AM
mashinter's Avatar
mashinter
3 inches is in dropped spindle territory.
Old Oct 13, 2010 | 11:23 AM
jordan89's Avatar
jordan89
Old Oct 13, 2010 | 07:17 PM
Sho'nuff's Avatar
Sho'nuff
http://i1131.photobucket.com/albums/...100_0436-1.jpg
http://i1131.photobucket.com/albums/...e/100_0442.jpg
may need taller tires 245-45 ZR17
Old Oct 14, 2010 | 12:11 AM
MN80Vette's Avatar
MN80Vette
Have you considered switching to a front mono spring? That allows you to lower the front the same way you lower the rear. That's what I have, and I like it a lot. I can adjust the stiffness too.
Old Oct 14, 2010 | 10:07 PM
Sky65's Avatar
Sky65
St. Jude Donor '05, '09, '15
Use 255/50 X 17. Same diameter as stock tires. That will fill the wheel well.
To Front springs
