Rust Removal
Old Apr 1, 2002 | 11:53 PM
hpeters's Avatar
hpeters
8th Gear
Default Rust Removal
Any ideas on a good product to help with remvoing rust...
Hal Peters
71 Roadster (my first vette)
Old Apr 2, 2002 | 12:00 AM
bence13_33's Avatar
bence13_33
Default Re: Rust Removal (hpeters)
What exactly are you trying to remove rust from?
Old Apr 2, 2002 | 12:04 AM
Stingy74's Avatar
Stingy74
Default Re: Rust Removal (bence13_33)
I don't know if there's any product that will remove rust but there is a few that will seal and stop it. Rust usually weakens whatever it is holding together so the only real fix is to get new metal.
Old Apr 2, 2002 | 09:04 AM
KenSny's Avatar
KenSny
For small areas I use Naval Jelly, carried by most auto parts stores. Follow the directions, clean good, and use a good primer before painting.
[Modified by KenSny, 8:05 AM 4/2/2002]
Old Apr 2, 2002 | 09:32 AM
Milest's Avatar
Milest
Default Re: Rust Removal (KenSny)
I have had good luck with a product called Ospho on rusty boat trailers. Available at hardware stores. It converts the rust and allows you to paint. Do not remove (sand, wire brush) the treated metal and it will hold up better.
Old Apr 2, 2002 | 09:48 AM
Sharky Guam's Avatar
Sharky Guam
Default Re: Rust Removal (Milest)
There are a number of spray on corrosion killers that dry to a primer like finish. go to a marine dealer and ask what they stock. :cheers:
Old Apr 2, 2002 | 01:35 PM
John Cassidy's Avatar
John Cassidy
Default Re: Rust Removal (Sharky Guam)
I've had great results using a local commercial paint stripping organization. They acid dip what ever you give them and the metal comes out looking like new. The cover it in a light rust protectant (water based) that you just wash off before painting. Typical price is $15 for a lower control arm. I always use POR15 to topcoat.
Old Apr 2, 2002 | 01:40 PM
Steve Adkins's Avatar
Steve Adkins
Default Re: Rust Removal (John Cassidy)
What do you use if you can't get to the area you are wanting to treat, like the inside of the frame?
Old Apr 3, 2002 | 12:07 AM
hpeters's Avatar
hpeters
8th Gear
Default Re: Rust Removal (Stingy74)
After further looking and poking I have decide that I would be better off the replce the piece. Thanks for all the help..
Hal
To Rust Removal
