i gotta 75 everything in it is stock. one day just decided to die. im not getting any spark to the engine. changed my spark plugs and wires. my distributor looks good. fuses are good. cant find any broken wires or anything. When i try to start it, it just turns over. any suggestions?
I see this is your first post. Did you just recently get the car?
I bought mine a month ago, everything was fine and one time, the engine turned over but no firing of any cylinders.
Turns out mine had a manual killswitch under the dash. Kind of a homemade 70s anti-theft gizmo. I'm glad someone suggested this possibility before I started tearing things open and buying parts!!!!
Is yours recently purchased? If so, are you sure you didn't flick a 'mystery switch' by accident?
yah i bout it september 15th and it was running great.
