water pump help
Old Oct 14, 2010 | 03:28 PM
FedorC3's Avatar
FedorC3
Default water pump help
i am having a hard time finding one for my '80. the numbers on the original are (330 818) and (C180 GM) if that helps. the original pulleys on all the new pumps ride the pump please tell me what i need. thanks.
Old Oct 14, 2010 | 05:12 PM
KevinK's Avatar
KevinK
Autozone not only carried a waterpump for my 76', they had it in stock at the store that day. Give them a try.
Old Oct 14, 2010 | 05:17 PM
Scott Marzahl's Avatar
Scott Marzahl
I prefer to use AC Delco parts, your GM dealer should have a pump or rockauto.com carries Delco parts.
A/C Delco part number 252585.
Old Oct 14, 2010 | 05:52 PM
FedorC3's Avatar
FedorC3
thanks ill try them out. how about this:
http://www.stewartcomponents.net/Mer...y_Code=ChevyS1
Old Oct 14, 2010 | 06:00 PM
Scott Marzahl
You don't need a high flow pump in a stock car, they can actually cool less.
Old Oct 14, 2010 | 06:15 PM
FedorC3's Avatar
FedorC3
ok i see. tnx
I just don't want to get the wrong one again. Can someone give me a link to the exact pump that fits in to a stock '80.
Old Oct 14, 2010 | 08:12 PM
Ironcross's Avatar
Ironcross
Originally Posted by FedorC3
ok i see. tnx
KevinK above has supplied all the information you will need and those are new pumps..not rebuilt...buy parts local, quick service and correct parts with great warranties and prices
Old Oct 14, 2010 | 09:39 PM
noonie's Avatar
noonie
No matter where you get your pump, check the measurement from the block mount face to the clutch mount face, Should be 5.795" for the 80 Corvette pump.
The Stewarts pump you linked to is a great pump, use them all the time, but should not be necessary.
Old Oct 14, 2010 | 11:30 PM
snoopykissedlucy's Avatar
snoopykissedlucy
I had the same problem with my 1980 Vette pump replacement.
Here in Dallas, TX....the Autozone website was listing the long water pump...which we all know is wrong. I went to pepboys, they had the right one....$30....I bought two just because my daughter has a 1976.
To water pump help
