383 stroker or BB
Old Oct 16, 2010 | 07:42 AM
omegac1's Avatar
omegac1
Default 383 stroker or BB
I currently have a new to me 1968 with SB 350 bored .030 over motor with hooker side pipies headers and 4.10 rear with stock 4 speed tranny. I want some more hp(say 450-475) and looking for the best move. The motor I have has few miles on it and has, roller rockers, Dart 2 heads ported and polished, pink rods, some performance cam but I dont know the specs and forged crank. I wonder how much hp I have now....375 ish? Also, along with the motor chnages I plan on going to a 5 speed conversion. So which way to go for most bang for the buck?
Since the motor is relatively new do I have it stroked out to make it a 383 or is it cheaper to get a "new" 383 long block and move externals to that? What new internals would be needed if I did this?
Or do I go the say 454 or 502 BB route?
Old Oct 16, 2010 | 08:15 AM
kellyr073's Avatar
kellyr073
I went with a stoker, revs fast, plenty of HP, lots of torque, and lighter than most BB's. Just my POV.
Old Oct 16, 2010 | 08:20 AM
U17's Avatar
U17
I went with ZZ383 from Summit ....
Old Oct 16, 2010 | 09:05 AM
3JsVette's Avatar
3JsVette
What's the budget? Do you have a "good" engine builder in your area? How much of your current engine would you be able to re-use? That may be the most cost effective way to go. A crate motor with that kind of power will be in the 5K+ area. Now add in the 5 speed and the money adds up quick. If you go the big block route you will need to change a lot more. Headers, pulleys, ect,............is the radiator capable of dealing with that kind of power? The money starts adding up real quick! Something to think about before deciding which way to go. Good luck with what ever you decide.
Old Oct 16, 2010 | 09:43 AM
John 65's Avatar
John 65
It adds up VERY quickly. Pulleys, brackets, exhaust manifolds, exhaust pipes, hoses, belts, hood, paint for hood, trim for hood, stronger front springs, radiator, rad support ? shroud ? starter ? Did this for a friends car. Was it worth it...YOU BETTER BELIEVE IT ! Good luck which ever way you go.
Old Oct 16, 2010 | 09:51 AM
cottoneg's Avatar
cottoneg
If you road race, the weight savings of a small block would matter.
If you drag race, you can get more HP out of the big block.
If it is just for the street, save money and go the cheapest route.
Old Oct 16, 2010 | 10:17 AM
omegac1's Avatar
omegac1
Im leaning towards stroking out my current engine. I have a good machine shop down the road. What would need to be done?
Block machined for the new rods and ???
New crank and rods becase of the different stroke ?
Can the exisiting pistons be reused?
The car already has a BB radiator.
Old Oct 16, 2010 | 10:36 AM
Billysvette's Avatar
Billysvette
All you have to do is add one of these to your 350 engine to get those hp numbers
Old Oct 16, 2010 | 12:09 PM
82CEtuner's Avatar
82CEtuner
I agree go with a roots supercharger and your there
Old Oct 16, 2010 | 07:32 PM
straub18045's Avatar
straub18045
superchargers do have a cool factor, but i like to make a motor alittle more like a sleeper. go 383, machine shop will go with there recipe for what works for them, cheaper than going bb but with a solid 383 you will have bb power, or can go crate motor but wont have the quality of a machine shop doing your motor. inop
Old Oct 16, 2010 | 07:37 PM
mj9311's Avatar
mj9311
well if its already bored .030 over just stroke it
Old Oct 17, 2010 | 09:04 AM
omegac1's Avatar
omegac1
If I have them stroke my existing .030 over motor, can they reuse my forged crank and just put longer rods in or does the crank change too?
Old Oct 17, 2010 | 10:55 AM
SteveG75's Avatar
SteveG75
Need a new crank. That is what determines the stroke. Also need new pistons with revised pin location. Rods can probably be reused.
Old Oct 17, 2010 | 12:10 PM
MarkZ's Avatar
MarkZ
I built my 383 with original rods new pistons and a 383 crank - and a new 400 damper - which means the timing marker needs to be modified/replaced. Unfortunately I still havn't had it on the road so I don't know the numbers yet - but the end is in sight
Camel heads - Magnum roller rockers - Lunati 310A8LUN cam edelbrock performer intake -Dynamically Balanced and Anti pump up lifters. she sounds sweet.
Old Oct 17, 2010 | 07:46 PM
OzzyTom's Avatar
OzzyTom
Given the choice of internally balanced vs externally balanced rotating assembly for your stroker.... my advice is pay the extra for internally balanced.
By the way, I swapped out my 327 to a 475hp 383 stroker with a 5sp Tremec.
Chalk and cheese!
Amazing change in the whole driving experience.
Old Oct 17, 2010 | 08:05 PM
Indiancreek's Avatar
Indiancreek
Check this month's edition of Super Chev. mag. They have a bunch of different types of set ups based on the wanted Horse Power. Several 383 set ups. Keep in mind you'll end up in stall speed converter ville in short order.
To 383 stroker or BB
