I'm in real need of pics and diagrams of the tilt/tele column.
I've tried accessing the info by Jim Shea at CorvetteFaq but they will not work for me. Any ideas?
Thanks!
Haynes manual actually has a decent picture, beleive it or not. Also, the Dr. Rebuild catalog (as usual) has a good diagram. What are you removing/fixing? Or are you just tearing it apart for the sheer joy of it :smash: :crazy:
I don't think it's going to be all that hard. BUT I needed the diagrams for a couple reasons. I'm missing everything north of the tele ring so I need to know what to buy. I need to remove the lower ring and replace it. I need to change the key lock as well. I want to pull it apart and give it a complete rebuild. Once the column is complete, painted, and the new parts are changed out - I think the install itself will be a breeze.
There's a supplier somewhere that was mentioned in a thread a while back who refurbs and sells teletilts. I'm sure he will have what you need. A search or a general request for help might turn him up.
W.
