OEM roller cam conversion
Old Oct 20, 2010 | 11:17 AM
65air_coupe's Avatar
65air_coupe
Default OEM roller cam conversion
I bought the parts a couple of years back and have now lost the instructions on modifying pre 85 blocks for this conversion. Can someone upload or email them to me?
TIA
pdeinc01 at gmail dot com
Old Oct 20, 2010 | 11:34 AM
MelWff's Avatar
MelWff
http://www.chevyhiperformance.com/te...cam/index.html
Old Oct 20, 2010 | 01:17 PM
65air_coupe
Thanks but I am looking for the instructions that cover using OEM dogbones and spider. There are slight modifications required to the lifter valley, tapped holes for the spider and some clearancing for the dog bones. It's that latter part I'm interested in. Pictures would be great if anyone has done that mod themselves.
Old Oct 20, 2010 | 02:37 PM
toddalin's Avatar
toddalin
You may find this information useful too.
http://www.carcraft.com/techarticles...ock/index.html
Old Oct 20, 2010 | 03:19 PM
dochorsepower's Avatar
dochorsepower
I think I know what you're talking about. Several years back there was a guy on Ebay selling instructions on how to clearance the back of the lifter bore casting area for the dogbones, also the listing for the short V-6 style roller lifters. He also hinted that he had some issues with oiling quantity to the rocker arms. Personally I wouldn't recommend this method unless you're open to a lot of experimentation, trouble-shooting and risk to your engine build. Go with after market retrofit roller followers.
Old Oct 20, 2010 | 03:37 PM
midyearvette's Avatar
midyearvette
i can't imagine the machine work required to put the later style set up in an older build, it has to at least match or exceed the cost of the retro roller setup...jmo...
Old Oct 20, 2010 | 04:10 PM
Scott Marzahl's Avatar
Scott Marzahl
Ya, DurangoBoy had those instructions. He emailed them to me years ago but the whole thing was such a kluge I deleted the document. He might be over on the "other" site.
Old Oct 20, 2010 | 04:12 PM
crf311's Avatar
crf311
I got them, just need to find them. I'll let you know.
Old Oct 20, 2010 | 04:13 PM
crf311's Avatar
crf311
Found them. They are in PDF file what's your email?
Old Oct 20, 2010 | 04:25 PM
Scott Marzahl
Its in his first post.
Old Oct 20, 2010 | 04:51 PM
fotyfobravo's Avatar
fotyfobravo
From: Lake Arrowhead - Georgia > 72 Base Coupe & 74 BB Roadster
Wow...DurangoBoy.......haven't heard that in a while...where'd he go?
Old Oct 20, 2010 | 04:59 PM
Scott Marzahl
He was banned from camp for something to do with the moderators. Maybe over at digital, don't know.
Old Oct 20, 2010 | 05:03 PM
crf311's Avatar
crf311
Sent it
Old Oct 20, 2010 | 06:38 PM
65air_coupe
Got it...thanks so much!
I gave this serious consideration when I first was looking at building my 406 and after looking at the pictures and reading the instructions, it's really not much of a job at all. I had the machine shop that was doing the other work on the block face, drill and tap the holes for the spider so all I have to do is a bit of grinding for dogbone clearance.
The oiling issue is news to me but should be simple to ascertain before putting it on the road.
To OEM roller cam conversion
