Need temp sending unit OD 5/8 coarse thread
Old Oct 21, 2010 | 01:51 PM
hammondo's Avatar
hammondo
Default Need temp sending unit OD 5/8 coarse thread
My 1980 L82 has a non-stock Wieand manifold - part of a recent engine rebuild. The temp sending plug takes a 5/8" coarse thread OD sending unit. The old unit prior to this last rebuild of the engine is broken so it can't be used (old manifold was also non-stock and had a 5/8" OD sending unit).
I ordered a stock sending unit but its OD (Outer Diameter) is 7/8" so it won't match. I worked with a regional screw/bolt company (Tacoma Screw) but they contacted every one of their suppliers and not one was interested in making a spacer that would drop down in OD and yet be hollow so the fluid would reach the sending unit.
Anyone have any ideas how I could get my hands on a temp sending unit with 5/8" coarse thread outer diameter? If I go to a parts store I just stump the guy as he needs to know the car make/model/year to search for.
Thanks all,
Steve
Old Oct 21, 2010 | 02:31 PM
Garys 68's Avatar
Garys 68
Are you sure it's not 1/2"NPT?
Old Oct 21, 2010 | 02:46 PM
hammondo's Avatar
hammondo
NPT means? Sorry, a bit of fuzzyness in the old brain this morning. I measured both the ID on the plug on the new manifold, and the OD on the old sending unit (that plugged into the now-retired-and-hanging-from-my-garage-wall old intake manifold) which would screw into the temp plug on the new manifold ok, and they both measure 5/8".
Old Oct 21, 2010 | 03:29 PM
1Fordman's Avatar
1Fordman
Most sending units that contact fluids are NPT which is pipe thread.
A 1/2" pipe thread sender will have a bigger outside diameter. Pipe size is the inside diameter measurement.
Old Oct 21, 2010 | 03:46 PM
hammondo's Avatar
hammondo
I understand that pipe thread is measured by the inside diameter - for the longest time I did NOT know that but I was kindly made to understand that recently by a plumber friend. I'm referring here to the OD (Outer Diameter) of the sending unit as it has to thread into the ID (Inner Diameter) of the temp plug on the intake manifold. As I mentioned I have measured both and they are 5/8" coarse thread.
Old Oct 21, 2010 | 04:06 PM
1Fordman's Avatar
1Fordman
You have me thinking, the aftermarket sending units (VDO, Stewart-Warner & Autometer) sometimes use sending units with a smaller OD than the stock senders. Do you have the original gauges in your car?
I have an Edelbrock manifold on the 68 and it's water temp sending unit hole is for the larger OD (original) sending unit.
Old Oct 21, 2010 | 04:23 PM
hammondo's Avatar
hammondo
Yep original temp and oil pressure gauges but I am replacing the oil pressure gauge with a mechanical one - when I hit the 500 mile point on the engine break-in (yes it's that new) as the old electrical was NOT accurate.
Old Oct 21, 2010 | 05:35 PM
Garys 68's Avatar
Garys 68
Every non-metric fitting I've seen for a temp fitting is NPT, pipe thread. Go to Lowes, get a 1/2" NPT and 3/8" NPT plug. One will fit. BTW NPT is tapered so it should tighten as it goes in.
If your new sender is smaller, just get a 1/2" NPT to 3/8" or 1/4" reducer, about $5 for both.
Also pick up some teflon pipe sealant paste. Use that to have a ghood seal and wont interefere with the senders grounding.
Old Oct 21, 2010 | 05:48 PM
hammondo's Avatar
hammondo
Sorry Garys 68 I am not understanding what you are saying here. To me a plug is what is already in the hole in the intake manifold where I need to install the temp sending unit ergo why would I need another one? I need, if I am to use the stock temp sending unit I just purchased (7/8" outer diameter, for 1979-1980), to drop down from 7/8" inner diameter (to accept the sending unit) to 5/8" outer diameter (to thread into the hole on the intake manifold) using some sort of threaded (inner threads on one end, outer threads on the other end), hollow adapter.
Old Oct 21, 2010 | 07:13 PM
bluthundr's Avatar
bluthundr
Another vote for it's probably 1/2" NPT
Old Oct 21, 2010 | 07:54 PM
John A F's Avatar
John A F
You can go to any hardware store and ask for a brass 1/2 by 3/8 NPT pipe reducing coupler and a 3/8 NPT pipe close nipple. That should let you fit the larger sender into the smaller hole in the manifold. Screw the sender into the larger end of the reducer coupler, the close nipple into the smaller end of the reducer, than screw the entire assembly into manifold. Also, I've been told, to use a paste type thread sealer rather than teflon tape sealer, as the teflon tape will not allow a good electrical contact.
Old Oct 21, 2010 | 09:30 PM
GUSTO14's Avatar
GUSTO14
Steve, is this what your temperature sending unit looks like?
Is there enough material around the existing hole in the manifold to tap it out to the size of your new sending unit? These sending units are definitely NPT and require special taps. Do not try to substitute a standard SAE tap.
My concern with trying to use an adapter that reduces down to the size hole in the manifold is that the sending unit may not reach the water and may even have a small air pocket in the adapter around the probe..
By the way, doesn't the temperature sender in your engine screw into the head between the exhaust ports?
Good luck... GUSTO
Old Oct 21, 2010 | 10:17 PM
mj9311's Avatar
mj9311
http://www.zip-corvette.com/ProductD...GR-SR&CTitle=&
Old Oct 22, 2010 | 12:21 AM
hammondo's Avatar
hammondo
The intake manifold is a Wieand 8120:
http://www.jegs.com/i/Weiand/925/8120/10002/-1
Where the temp sending unit hole is, is on the drivers side front of the manifold. Passenger side front is a 5/8" inner diameter hole for the return heater hose - I know this because I purchased an adapter at an auto parts store that was 5/8" OD on one end, had a hex in the middle for tightening, and had a lip on the other end for putting the hose on and clamping it down. Both front end intake manifold holes are the same size - 5/8" inner diameter.
Yes Gusto that is EXACTLY my stock replacement temp sending unit - purchased it from Ecklers before I realized it was too big. Also neither Ecklers or Zip had any measurement info for that unit on their web sites.
I've never used a tap and die and am hesitant about getting metal shavings in the cooling system. Good point on the possibility of an air pocket between the sending unit and the coolant. Think I'll keep beating the bushes for a 5/8" outer diameter sending unit.
Old Oct 22, 2010 | 08:50 AM
jackson's Avatar
jackson
Originally Posted by GUSTO14
Steve....By the way, doesn't the temperature sender in your engine screw into the head between the exhaust ports?
Good luck... GUSTO
hammondo ... suggest install your new sender into the OEM '80 cylinder head ... also, block any unused intake water hole(s) with plug(s) having tapered pipe thread.
Old Oct 22, 2010 | 12:44 PM
hammondo's Avatar
hammondo
Spoke with the engine builder - they purchased the current block (Corvette 350 block) for me back in 2000 for another build. They recommend NOT using that drivers side manifold hole as should coolant be low that will be the first place where an air pocket will develop and the sending unit would then not be able to detect any temp.
Their guess on the engine block hole - between cylinders 1 and 3 - is 1/2" NPT and if not it should be 3/8" NPT and said that thread IS tapered so 1/2" NPT = 750-800/1000" and 3/8" NPT = 750-800/1000". Is that engine block hole what was being referenced in those guesses for 1/2" NTP?
Old Oct 22, 2010 | 02:47 PM
GUSTO14's Avatar
GUSTO14
Their guess on the engine block hole - between cylinders 1 and 3 - is 1/2" NPT and if not it should be 3/8" NPT and said that thread IS tapered so 1/2" NPT = 750-800/1000" and 3/8" NPT = 750-800/1000". Is that engine block hole what was being referenced in those guesses for 1/2" NPT?
Steve, the hole we're referring to is in the head (like this below), not in the engine block.
If the heads are stock (almost all aftermarket heads now have the hole in the same place) and the sensor is stock it should fit perfectly. The sensor I posted from Paragon and the link mj9311 posted from ZIP appear identical and are for a stock engine. I would wager they will fit in your heads. All you need to do now is determine which head to install it in.
Good luck... GUSTO
Old Oct 22, 2010 | 03:28 PM
hammondo's Avatar
hammondo
Oops, guess I just don't know my engine anatomy as well as I should - i.e. should have figured you meant the heads rather than the block. These aren't stock heads, they were installed in the 2000 build and I don't have that invoice in front of me and cannot recall offhand what they were but they were still in great shape to be reused for this recent build (side note).
The engine builder mentioned since I have headers it is likely it will be a real bitch (his exact words) to turn that plug. Since I will have to drain the coolant I will probably wait until spring to do this - up here in the NW it's getting close to the time I park it for the winter.
I'd provide pictures but *crap* lost my camera on a hunting trip last week.
Thanks all,
Steve
To Need temp sending unit OD 5/8 coarse thread
