Going through the parts I have tucked away over the years, I found this alternator, if I remember correctly it was off my 94 TA way back when.......I would imagaine this is the CS144 style that everyone refers to for the alternator upgrade. So am I safe in assuming that I could use this for the 454 if I want to make the switch?
Just found the alt from the 454 and the bolt holes match perfectly, same height from the ground up on both sides, so it should be a bolt on with no problem, all I would need is the adapter? correct? And a kit to do a rebuild???
Thanks for any info or suggestions.................Tom
pics below......
