Spring bolts
Old Apr 2, 2002 | 10:09 PM
GTR1999's Avatar
GTR1999
Default Spring bolts
I have a replacement 9 leaf spring and new 6.250" spring bolts and cushions. Question is do I need the 8" bolts because the new spring will push th ebody high or not? The bolts came with the spring sO I figured that would be ok?
Gary
Old Apr 2, 2002 | 10:28 PM
Matt M's Avatar
Matt M
Default Re: Spring bolts (gtr1999)
Can't hurt to try them since they are easy to change.
Matt
Old Apr 2, 2002 | 10:43 PM
75 Hot One's Avatar
75 Hot One
The shorter bolts should be O.K. and should give stock ride height. The 9 leaf spring is relatively soft & will flex. If you want to lower the rear end, the 8" bolts will provide more adjustment. You can install the 8" with the spring just in case, if you want. Then you'll have room for adjustment if you want it down the road.
Old Apr 3, 2002 | 12:26 AM
GTR1999's Avatar
GTR1999
Default Re: Spring bolts (75 Hot One)
Thanks,
I guess I'll stick with the bolts I have and see. They are drilled for the slotted nuts too I don't know if the 8" bolts are?
Gary
To Spring bolts
