C4 seat swap
Old Oct 24, 2010 | 06:36 AM
bigjoepos's Avatar
bigjoepos
Default C4 seat swap
Looking at the possibility of 95 seats.
I have seen a number of older threads with C5 seats installed into a C3 but not many C4 seats in a C3.
Anyone with any experience with this swap?
Are the C4s wider than the C5's and do they sit too high (floor to top of bottom cushion).
Old Oct 24, 2010 | 09:08 AM
PUNISHER VETTE's Avatar
PUNISHER VETTE
Old Oct 24, 2010 | 09:20 AM
Gordonm's Avatar
Gordonm
The C4 seats fit very good in the C3 cars and many here have done. this swap. I personally have a set of C5 seats in mine but the C4s will fit also.
Old Oct 24, 2010 | 10:32 AM
PUNISHER VETTE
All I know is I loved the seats that were in my 96 vette. So if C4 seats fit just as well as C5 seats and can be had for most likely cheaper then i'm going to be all over it as well.
Old Oct 24, 2010 | 07:27 PM
Will's'74VetteL-82's Avatar
Will's'74VetteL-82
I am planning on putting c4 seats into mine when I install the interior. The ones I'm going to install are the earlier ones (up to 88). I think you either need to change c3 tracks to fit the seats or you can modify the seats to fit the tracks. Here is the link to my thread about c4 seats in a c3 corvette- http://forums.corvetteforum.com/c3-t...-corvette.html
Will
Old Oct 24, 2010 | 11:58 PM
S&S_ShovelHead's Avatar
S&S_ShovelHead
I have c4 seats in mine, they fit pretty well and have good lateral support.
Old Oct 25, 2010 | 12:53 AM
bigjoepos's Avatar
bigjoepos
Thanks for feedback.
I recall the thread but could not find it for some reason.
Good point about the C4 headrest tilting forward.
Old Oct 25, 2010 | 08:14 PM
Will's'74VetteL-82
Yep, If you do it to your car, take some pictures of the finished result!
Will
Old Oct 26, 2010 | 07:47 AM
markdtn's Avatar
markdtn
I had an old Ecklers catalog that says all you need is your original seat tracks and just bolt to the bottoms of the C4 seats. I was going to go that way and actually bought a pair and had them in the car loose while I finished it, but ended up with late C3 seats.
Old Oct 26, 2010 | 08:54 AM
Denpo's Avatar
Denpo
tall person question, does the C4 seats sit higher than early C3 ones?
Old Oct 26, 2010 | 09:45 AM
S&S_ShovelHead
Thats how mine are installed.
Ive never sat in stock c3 seats but I couldn't imagine them being lower than my c4 seats. The stock tracks bolt right into the seat pan and its just the lower pad on top of that.
To C4 seat swap
