79 Resto Questions
Old Oct 26, 2010 | 04:44 PM
76yellow's Avatar
76yellow
Default 79 Resto Questions
I have a 79 that I am restoring. By the vin # it was an L48 Auto but now it is an L82 4spd. My question right now is about cruise control. The brake light switch is for cruise, there is the transducer down under the master cylinder with 2 speedo cables. But there is nothing on the steering column to activate cruise. It appears to be the original column so what would activate the cruise/ Or should I just eliminate all the cruise stuff & forget it ? I'l appreciate any & all input....Thanks
Old Oct 26, 2010 | 05:25 PM
MelWff's Avatar
MelWff
I could be wrong, and if I am Im sure someone else will point that out, but I'm under the impression you could only get cruise control with an automatic
Old Oct 26, 2010 | 07:19 PM
KapsSA's Avatar
KapsSA
Active Streak: 90 Days
There was just a single button at the end of the turn signal stalk. No resume or reset or anything else like you'd find on a more modern car.
And like mentioned, from the factory, you could only get cruise with an automatic.
Old Oct 26, 2010 | 08:13 PM
C3 4ME's Avatar
C3 4ME
I guessing they hadn't implemented the technology to cancel the cruise with the clutch pedal.
Old Oct 26, 2010 | 08:29 PM
76yellow's Avatar
76yellow
As I said, the car was born an L48 with auto transmission but someone before me converted it to an L82 & a 4spd. Thanks for the replies, I'll just eliminate all the cruise stuff that is left.
Old Oct 27, 2010 | 10:59 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by 76yellow
...As I said, the car was born an L48 with auto transmission...
And optional cruise control.
FWIW: someone will want your cruise control parts.
To 79 Resto Questions
