Muncie Input shaft question
Old Oct 28, 2010 | 11:07 AM
Jackk's Avatar
Jackk
Default Muncie Input shaft question
Hi , I can move the end of the input shaft up and down approx. 1/16 of an inch or so. Is this normal? There is no oil in the trans.
Thanks Jack
Old Oct 28, 2010 | 11:55 AM
AzMotorhead's Avatar
AzMotorhead
Limping across the line
1/16 isnt too bad. Do you have the front bearing cover off? Take a look and see if play is at front bearing. If shaft isn't rubbing on front bearing/input cover you're ok
Old Oct 28, 2010 | 11:59 AM
Young69Owner's Avatar
Young69Owner
I'm pretty sure there is a small amount of play in any transmission. My 4 spd had some wobble.
Old Oct 28, 2010 | 12:18 PM
bashcraft's Avatar
bashcraft
It's fine. The pilot bushing supports the front of the shaft.
Old Oct 28, 2010 | 12:25 PM
Jackk's Avatar
Jackk
Thanks I will take the cover off and take a look
Old Nov 18, 2010 | 09:21 AM
Burnt71's Avatar
Burnt71
To Muncie Input shaft question
