Mystery box and toggle switch
Old Oct 30, 2010 | 04:16 PM
Dano86's Avatar
Dano86
Default Mystery box and toggle switch
Both on left (driver) side of car. First is a black box down by the fuse panel. It is a black box about 2 ¾ square and ½ in thick. It says Phillips on it and on the bottom of one side had a little, maybe an inch, circle that has speaker like holes in it. Second is a toggle switch (on and off positions only) on the right side, above accelerator petal, on the duct for the A/C / heater vents with the wires running inside the duct.
Does anyone know that either of these things are??!?
Thanks for your time,
Dan
Old Oct 30, 2010 | 04:18 PM
baxsom's Avatar
baxsom
flux capacitor
Old Oct 30, 2010 | 04:20 PM
Dano86's Avatar
Dano86
flux capacitor = black box?? there is a green and orange wire that look like they should be pluged into it what one goes in front?
Old Oct 30, 2010 | 04:22 PM
dannyman's Avatar
dannyman
"Phillips automotive" may be light related. Don't have any neon tubes underneath the vehicle?
Doesn't sound stock.
Old Oct 30, 2010 | 04:23 PM
SanDiegoPaul's Avatar
SanDiegoPaul
From: San Diego - Deep Within The State of CONFUSION!
The box is either a headlight, seatbelt, or some other buzzer.
Old Oct 30, 2010 | 04:33 PM
Dano86's Avatar
Dano86
No extra lights anywhere i have found.
I was thinking possibly a buzzer for something but no clue found the number 377596 but couldn’t find anything online. There is a female harness with a green wire and an orange wire with a place on the box for it to plug in but haven’t tried it yet
Old Oct 30, 2010 | 05:04 PM
Dano86's Avatar
Dano86
box is a buzzer thanks yall. Now to trace that toggle switch
Old Oct 30, 2010 | 10:15 PM
my 76 ray's Avatar
my 76 ray
The toggle switch is probably the rear window defogger. On '74 and prior years there is a fan that blows across the rear window. On '76 and later years there is a heating element on the rear window. I'm not sure which of those the '75's have.
Old Oct 31, 2010 | 12:49 PM
whitehause's Avatar
whitehause
The rear defog switch on my 68 is a rotary ****(low-off-high) on the small access panel at the lower drivers side of the center console, but I'm not sure if this holds true for all years that had it. A pic would be helpful, but it doesn't sound like a factory option. Might have been for an aftermarket alarm system, or electric fuel pump.
To Mystery box and toggle switch
