Need Paint Code for '68 Rally Red
Old Apr 3, 2002 | 03:17 PM
MWILLET's Avatar
MWILLET
Default Need Paint Code for '68 Rally Red
I happened to see a '68 in Rally Red the other day (that's what the owner said the color was). I think this color would look great on my '80, but I'd like to know the paint code.
Old Apr 3, 2002 | 03:25 PM
ComputerGuy's Avatar
ComputerGuy
Default Re: Need Paint Code for '68 Rally Red (MWILLET)
Code for Rally Red is 974. There were 2918 of them made.
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
'68 Rally Red. One year only.
4688-LH for Dupont;
A-1744R for Rinshed-Mason;
71491 for Ditzler.
All above are for the original acryllic lacquer. Your paint supplier should be able to take any of those numbers and come up with a match. Good Luck.
Old Apr 3, 2002 | 03:27 PM
lbell101's Avatar
lbell101
Default Re: Need Paint Code for '68 Rally Red (Easy Mike)
I don't think it was one year only. '66 looks the same: http://www.corvette.net/paint-3.htm
Old Apr 3, 2002 | 03:32 PM
1LE's Avatar
1LE
Paint code 974 rally red, for 68. same code for monza red for 69 & 70.
Old Apr 3, 2002 | 03:39 PM
ComputerGuy
According to VetteSet and BlackBook, Code 974 was Rally Red in 66, 67, 68. In 65 Rally Red was UU.
Old Apr 3, 2002 | 03:40 PM
Easy Mike's Avatar
Easy Mike
Paint code (974) is the same. The OEM paint numbers are different which means the colors are slightly different or a change in paint formulation occurred. The numbers I listed are for the OEM '68 lacquer and they do not cross match with any other year. Hence, one year only.
Old Apr 3, 2002 | 03:47 PM
lbell101's Avatar
lbell101
The OEM paint numbers you posted are the same as the ones in the link I posted for '66. Hence, not one year only! :D
Old Apr 3, 2002 | 03:58 PM
MWILLET's Avatar
MWILLET
Thanks for all the info, guys! If the owner of the '68 was correct in what he told me, my car will end up a medium-to-dark red, right?
To Need Paint Code for '68 Rally Red
