Rear Window
Old Nov 1, 2010 | 12:00 PM
Del96lt1's Avatar
Del96lt1
Default Rear Window
All,
Working on a '76. Has anyone removed and resealed their rear window ?? I've got a leaker. Any and all advice would be much appreciated.
Thanks,
John
Old Nov 1, 2010 | 01:02 PM
oldsarge's Avatar
oldsarge
If it is still a factory install, it is just pressure fit with a butyl type caulking. You can carefully use a putty knife or hard plastic putty knive to loosen the membrane from the outside. Be carefull not to scratch the glass or the paint. Work and poke your way around the window, and apply a little pressure on the glass to the inside, as you work your way around it will loosen up and have someone catch it on the in side. Once you have it out, clean any remaining membrane from the body and clean up the glass. You can get the butyl membrane from a local auto glass dealer or from the aftermarket, corvette suppliers. The membrane is placed around the clean window and just pressure fit back in place. Hope this will help.
Old Nov 1, 2010 | 01:31 PM
brando1118's Avatar
brando1118
You are going to a lot of work to pull your rear window. Why not convert it to the "removable" rear window? It takes a lot of wind noise out of the **** pit while driving with the T-Tops off. Good luck.
Old Nov 1, 2010 | 01:36 PM
Del96lt1's Avatar
Del96lt1
Default Rear Window
Sarge,
Thanks. It appears that a PO attempted to reseal it with ??. I'm hoping it comes out easily. Thank you again for the advice.
John
Old Nov 15, 2010 | 08:55 PM
rcsdvette's Avatar
rcsdvette
Is there such a thing as a removeable window kit for 74-77's???
Old Nov 16, 2010 | 06:08 AM
brando1118's Avatar
brando1118
Give this a whirl
http://www.europeancorvette.com/html...ear_window.htm
Old Nov 16, 2010 | 09:31 AM
ANY VETTE's Avatar
ANY VETTE
Changed my 76 to a removable, and love it . I leave it out all summer, and just bring it with me in case it rains on trips.
To Rear Window
