I've researched and found no match to my problem, as far as I can tell.
Previous owner had butchered the underhood vacuum system in my '80. I bought and installed a new line kit with no real problems. All the vacuum tanks, etc were still in place. I used the instructions with the kit as well as my AIM to get it all correct, but I still have no working headlight doors. When I pull out the headlight switch, I hear a quick vacuum noise like the system is engaging. No lights pop up. They burn fine and I can manually (and inconveniently) pop them up for night driving. No leaks that I can locate, and I get good vacuum at the two inline valves, splitter, whatever behind the carb. Just nothing to pull or push the headlight buckets.
I'd really like to fix this but I don't know where to go from here.
Casey, just my two cents. Need to rebuild or replace your headlight vacuum canisters. After you know all hoses are right location using the diagrams. I went through everything to avoid replacing canisters but more than likely that is the problem. Thanks
replace the rubber boots on the canisters. this should fix the problem. One other thing is to check the switch underneath your steering wheel, that may be bad.
Agree dgood but the seals is what should be replaced. The rubber boots are used to keep dust, dirt and stuff off the shafts. And if the diapham is bad its no go. I would replace the whole canister but thats just me. I have found W/A/D/R replacing entire part is the way to go. But again thats just me. Thanks
You can test the actuators for leaks. Attach a hose. I can't remember which it is but sucking or blowing will make them go up. If you find its like blowing through a straw...no resistance the rubber boot is gone and needs replacing.
Disconnect the vacuum hose going to the resevoir. Hook a small vacuum pump ( a cheapie used for brake bleeding from China Freight or the like is fine) to replace the hose coming from the light switch and see if your lights raise.
If they do, start working back towards the dash and vac source. If they don't start working forward towards the lights (starting with the vacuum valve(s) .
The vacuum canister seal is usually the component that fails and causes headlight actuator problems. Rebuild kits are inexpensive and worth it as a first try to fix the problem. I had one that was malfunctioning, rebuilt it, and the other one crapped out. Rebuilt that one and they both have been working all summer. They don't rise at exactly the same time but as long as both of them raise up I really don't care.
I'll throw in another vote for getting a rebuild kit for the actuators. I did that on mine and it fixed the problem. What I noticed that caused me to rebuild them was that the dust boots were disintegrated. Cheap fix too, about $25 per actuator kit.
If you use a hand vacuum pump you should be able to hear if there are leaks.
As stated above, start with the pump connected to the actuator (test both the front and back ports as they should retain vacuum in both up and down positions) and move your way back towards the interior.
sgm 2004, you are right. I wasn't sure what they were called. I replaced my seals and they have been working good for the last couple of years. Lucky I guess because the rods are a little rusty. I have heard that the switch under the dash fails quite a bit or it is hooked up wrong.
Rick B.
I would like to know more about this statement.
All my headlight vacuum components and hoses have just been replaced. The passenger headlight pops up fast... but the driver side headlight comes up about 8 seconds later... and slower.
