383 camshaft selection
Old Nov 1, 2010 | 11:03 PM
Bowerss2's Avatar
Bowerss2
Default 383 camshaft selection
i need some advice on choosing a good camshaft for a 383 build. The goal is in the mid 400s for power (not more then 480hp)
Specs;
Brodix IK180 64cc heads;
.030 over bore;
Full length headers;
11.3:1 comp ratio;
Intake 2X4 carbs (thinking about switching to MPFI)
i hear that 110 lobe separation is best for 383s; why is that?
thanks all
Old Nov 1, 2010 | 11:41 PM
gkull's Avatar
gkull
Your problem with 11.3 is enough cam to get your dynamic compression down. You need at least 236 intake with a roller cam. I don't know much about flat tappet cams. But it might take something like advertised 284 to work
180 cc is very restrictive. 200 or 210 215 cc Darts work nice on small motors like a 383
cv67's Avatar
cv67
St. Jude Donor '05
No set rule of thumb on what LSA is best for any engine most go with it because it seems to be popular/everyone esle does type thing.
Depends a lot on needs, driving idle vacuum powerband range etc.
Old Nov 1, 2010 | 11:56 PM
gkull's Avatar
gkull
I have a 112 SR 236/242 on my 383 and it is pretty nice with a 5 speed
It depends on your whole motor as to what lobe center works best. 110 and lower gives the motor lots of overlap and the race car idle. Miles per gallon goes down also.
I had bad detonation problems with a 232/238 SR cam
Old Nov 2, 2010 | 09:34 AM
gingerbreadman1977's Avatar
gingerbreadman1977
your compression ratio is quite high for the rest of your combo but i would go no further than crane 119611 from the powermax series. its a small base circle roller cam retrofit so you will have no clearance issues . its a 112 lobe centre so you will have no vacum issues and will put you right around the 450 hp mark with great torque. you will need a 3000 stall or similar if you are driving an auto and at least 355 gears but other than that you will be smiling all the way from light to light.
Old Nov 2, 2010 | 10:21 AM
DRIVESHAFT's Avatar
DRIVESHAFT
Here is a Crane hydraulic roller that will do what you want. http://www.cranecams.com/product/car...detail&p=24188
The next smaller one would probably work too, but the DCR is a bit high. http://www.cranecams.com/product/car...detail&p=24192
Old Nov 2, 2010 | 11:55 AM
BLOCKMAN's Avatar
BLOCKMAN
11:03 with an aluminum heads is really not that bad we have done some 1:05 engines and no issues with Pump gas.
In this link Ken built a 383 engine and used a HYD roller the specs are posted and I talked to him last week and said at 40 miles an hour he can rip the tires off his car.
http://forums.corvetteforum.com/c3-t...-my-383ci.html
Old Nov 2, 2010 | 01:23 PM
pauldana's Avatar
pauldana
I am running the Edelbrock signature series retro roller cam... 10.5:1 compression, 440tq at the rear wheels..
but i have fond out how important the heads are in all this, that is to say the valve train itself.... SPRINGS, RR's, and LIFTERS...... in my case in changing out the springs, rr's and lifters, it was a difference of at least 50+HP..... these small things became major problems for me.... just FYI.... dont want to see you fight the same gremlins as I did...
Nobody.'s Avatar
Nobody.
For my '81 Vette street car, I built my 385 (.040" over) out of an '86up roller block and used a Crane billet HR part# 109841. It's 234/242 @ .050" on a 112 LSA. I used an old set of 487 LT1 iron heads milled to 71cc with 2.05/1.60 valves and professionally ported. Compression is at 9.8:1 with flattop SRP's. Motor is in the car but not running yet. 200r4 trans and a 2800 converter. I'm rebuilding the rear with a new gear (3.73), bearings, and bushings. Should be on the road later this month.
Old Nov 2, 2010 | 09:24 PM
BLOCKMAN's Avatar
BLOCKMAN
Specs;
.030 over bore;
11.3:1 comp ratio;
thanks all
It would be a good idea to pour the chambers of your heads to find out what they really are!!
We poured a set of AFR's that were suppose to be 65CC and when we checked them they were actually 67.5 which worked out perfect for our build.
Old Nov 2, 2010 | 09:31 PM
Bowerss2's Avatar
Bowerss2
very good idea i will do that tonight
To 383 camshaft selection
