They work by grounding the line anywhere. So there must be a short in the line somewhere. I would start by removing the door switches and see if its one of them.They can be a PITA to diagnose.
If memory serves, you can turn them on with the doors closed by turning the headlight switch **** to the last stop. Turn it back and see if they go out.
You should have 2 wires going to the socket (orange and white), the orange is hot 24-7,when the white wire is grounded the bulb comes on. The white can be grounded by 1 of the door switches or the headlight switch OR if a screw is run through it or its pinched. The white also runs to the rear compartment courtesy light.
