How do you adjust the headlights?
Old Apr 4, 2002 | 12:17 AM
74-Roadster's Avatar
74-Roadster
St. Jude Donor '06
Father & Son St. Jude Donor '09
Default How do you adjust the headlights?
Pursuing a, "While I'm at it . . . "
I've been reading the service manual on headlamp panel adjustment and I must admit, I not sure I understand what does what. Any simple tips before I start tinkering this weekend.
Specifically:
1. What stops the light in the open position?
2. Has anyone used the rebuild kit from Zip?
Old Apr 4, 2002 | 12:46 AM
Mike69@ECS's Avatar
0Mike69@ECS
Former Vendor
Cruise-In III Veteran
Cruise-In V Veteran
Default Re: How do you adjust the headlights? (74-Roadster)
Directly in the center of your linkage there will be a bolt going through the linkage whitch stops the light. Once you pull off your bezels, move your lights up and down once with your hand... the bolt I'm speaking of will be easy to spot.
Sorry I dont have a pic of it... I took 60 some pics when I did my headlight rebuild but failed to capture a clear shot of that bolt!!! :rolleyes:
You can take a look at the pics here http://community.webshots.com/user/mikesvette2 they are on page two.
Old Apr 4, 2002 | 11:01 AM
JohnS_77's Avatar
JohnS_77
Default Re: How do you adjust the headlights? (Mike69)
I am going to have to look at mine. They line up great when closed, but when they are up, the driver side is higher than the passenger side.
To How do you adjust the headlights?
