seams
Old Apr 4, 2002 | 12:25 PM
skinsfan's Avatar
skinsfan
Default seams
have any of you had the seams start coming apart on your vettes? I am going to get a paint job later this summer...I hope... and I will need to have the seams repaired... and suggestions?
Old Apr 4, 2002 | 01:05 PM
FeedVaal's Avatar
FeedVaal
Default Re: seams (skinsfan)
I had a little separation in the panel in front of the driver's door so I loaded it up with JBweld and called it good. Paint will cover a multitude of sins.
:cheers:
Old Apr 4, 2002 | 01:13 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
This is common on Sharks. The factory bonding material shrinks with age. It isn't yet noticeable on my '80. On my '68, I ground the seams and about an inch of the adjoining panels to bare fiberglass and laid up one course of fiberglass matte. One course was all I needed to raise the area. I sanded to contour, filled a pin hole here and there, and primed the areas. Never a problem since.
To seams
