heater core repair
Old Nov 12, 2010 | 04:14 AM
redvetteman81's Avatar
redvetteman81
Default heater core repair
I am getting ready to change my heater core. I understand that this is about a ten hour project. Can anyone give me any tips?
Old Nov 12, 2010 | 06:32 AM
Avette4me's Avatar
Avette4me
Cruise-In VIII Veteran
Here's a write up I did a few years back. Not that great but should help a bit.
Old Nov 12, 2010 | 07:37 AM
thegazman's Avatar
thegazman
Default thegazman
If you are going to go through all the work to replace the heater core, take to time to rebuild the entire heater box; new seals, etc. The doors will probably be rusty and need to be cleaned and painted. Also look at the vacuum hoses and replace as needed.
Old Nov 12, 2010 | 08:03 AM
Paul L's Avatar
Paul L
http://www.corvettemagazine.com/content/view/81/
Old Nov 12, 2010 | 01:40 PM
redvetteman81
thanks for all your help! guys, finally going to get this back on the road again after 2 years, corvette fever!
Old Nov 12, 2010 | 07:55 PM
sjr1971's Avatar
sjr1971
I have done this job two more times than I should have. Understand what I'm saying and save one go-around. Buy your new core in any part store. 90% it's from china. The port angles are wrong/brittle. They will break upon installation if not dead correct. The ports are not silver soldered in china. Take the core to a radiator shop. Remove your firewall by the fan [5 screws] Its width needs to be considered when re-silver soldering the ports. The next leak is a worn out core >20yrs from now.
Old Nov 13, 2010 | 04:40 PM
redwingvette's Avatar
redwingvette
I did mine this spring. The replacement core did not fit the same as the one I was replacing so I had to take extra care but it was not that bad of a job.
Heater core replacement
Old Nov 13, 2010 | 05:30 PM
Paul L's Avatar
Paul L
I went with GM/Delco/USA two years ago. About twice the price of the imports but it has held up fine. I do not know if it is still available.
Old Nov 14, 2010 | 09:11 AM
FlyViper's Avatar
FlyViper
Agree with the above. I suggest getting the rebuild kit from Zip or similar. Guarantee the foam inside that thing is all but demolished. I had to use a brillo pad and some goo-gone stuff to get it all cleaned up. The only issue is I have no idea how the hell I was going to use the OEM rivets to put all back together. I ended up just using a blind rivet tool and some blind rivets from Home Depot. They worked like a champ and are way easier than the included rivets in the Zip product. Also, definitely be very careful with the ports, they will not fit exactly, but with care you can get them in. I didn't have a need for them to be re-soldered, but your results may vary.
Old Nov 14, 2010 | 11:52 AM
Jack Wood's Avatar
Jack Wood
He's right! Do it all, do it right or do it twice. No shortcuts.
To heater core repair
