Been contemplating switching to coil overs on my '80.
Is there enough room to fit a 2 1/2" or 3" spring in there where the shock is now?
Also was wondering if it would work by coming off the rear of the trailing arm.
Weld a mount on the frame, Fab up some brackets to surround and box in the arm where the original bolt goes thru and come down from there. Seems to be a lot more room.
I don't think there would be any binding issues using coilovers with heim joints.
Anyone done this?
Thoughts?
Issues?
Reason I would like to do this is, I put in a replacement 9 leaf 2 yrs. ago and it still sits to high. Have 8" bolts in there now. 10" is too long, end of the spring rubs the sidewall. Plus, it would be something different. Hate following the crowd.
Almost forgot. Would the rates on both springs be 1/2 of what the leaf spring is or, say, a 200 lb. spring on each side if the leaf is rated at 400lbs.?
I have QA1s on all four (4) corners. This is a picture of the rear set-up before I completed and painted. Just a QA1 mounting kit bolted to steel plate welded to the trailing arm. No interference with the storage/battery compartments.
