1982 Rear brake caliper mating
Old Nov 13, 2010 | 11:10 AM
hubcap's Avatar
hubcap
Default 1982 Rear brake caliper mating
The bleed screw on the rhs rear caliper broke upon removing. Have located a used outer half that is in question.
My question is: Must the calipers be kept as a matched pair or can I mix the inner and outer used pieces?
Old Nov 13, 2010 | 11:29 AM
...Roger...'s Avatar
...Roger...
They are not matched. Don't forget the little o-ring.
Old Nov 13, 2010 | 11:33 AM
hubcap's Avatar
hubcap
Thank you Roger.
To 1982 Rear brake caliper mating
