Cam change?
Old Nov 22, 2010 | 07:15 PM
trainor's Avatar
trainor
Default Cam change?
I'm thinking of changing out the cam on my small block 1975 C-3. Does the engine need to come out or can I pull the radiator and do the job. Thanks
Old Nov 22, 2010 | 07:40 PM
RIO68's Avatar
RIO68
Rad. has to come out and a/c condenser moved forward if a/c car--. Tight fit just know you may have to move some stuff forward.
Old Nov 23, 2010 | 12:29 AM
trainor's Avatar
trainor
Default Whats Up
So this is a tech forum...........Hasn't anybody on here ever done a cam changeout? Come on guys chime in and help a guy out!
Old Nov 23, 2010 | 01:07 AM
babbah's Avatar
babbah
plus raiding the front of engine a bit higher to clear rad mount...
Old Nov 23, 2010 | 02:29 AM
FRSTR90's Avatar
FRSTR90
Rio68 pretty much summed it up.. no matter what way you look at it will be a PITA.. its a vette. If you're willing to take engine out, prolly a good time to take it completely down. It would definitely tell you if there's work needed to be done.
Old Nov 23, 2010 | 08:16 AM
BLOCKMAN's Avatar
BLOCKMAN
If your installing a performance cam I would suggest degreeing it in just to take out the fudge factor. And in the car its hard thing to do.
Old Nov 23, 2010 | 11:04 PM
babbah's Avatar
babbah
With engine in car - I threw mine in "straight up" - runs flawlessly
Old Nov 24, 2010 | 06:19 AM
baxsom's Avatar
baxsom
Its just that this question comes up a lot and there is tons of information all over the site already. People kinda expect everyone to search as much as possible and then ask questions on what they dont understand.
Old Nov 24, 2010 | 08:14 PM
babbah's Avatar
babbah
Old Nov 25, 2010 | 08:38 AM
RonR80's Avatar
RonR80
St. Jude Donor '09
I did the same just installed a comp cam,intake, runs like a charm , but if you remove the hood life gets easier, rad,fan, water, timing cover, gears and chain, and be carefull not to damage the cam bearings ,Ron
To Cam change?
