Previous owner/s Mods
Old Nov 23, 2010 | 02:52 PM
briaineo's Avatar
briaineo
Default Previous owner/s Mods
whats the best way to check for previous owners mods done to an engine?
Car i've got is a 69 with a 1978 305 in her. Prob only 145hp although seems like alot more.
Heads are original, air intake changer to a edelbrock performer and oil pan changed.
Car seems too zippy for the engine to be completely stock. Driven a good few mid seventies vettes and they all seemed way less powerful.
Old Nov 23, 2010 | 03:29 PM
CA-Legal-Vette's Avatar
CA-Legal-Vette
I can't think of a non-invasive way of checking the pistons or compression. Perhaps a compression test would give you some indication but not much more.
One thing you could do is degree your cam. This would give you an idea if it is stock or not.
Old Nov 23, 2010 | 07:47 PM
johnt365's Avatar
johnt365
what is the casting number on the block and heads?
Old Nov 23, 2010 | 08:46 PM
KTKelly's Avatar
KTKelly
I believe the stock 78 305 could have anywhere from 220HP to up around 350HP....
That helps a lot right?.....
Old Nov 23, 2010 | 09:13 PM
72LS1Vette's Avatar
72LS1Vette
Curious to know what 1978 305 engine made 350 HP stock. The optional Vette L82 350 was 220 HP.
Rick B.
Old Nov 24, 2010 | 05:24 AM
briaineo's Avatar
briaineo
GM T6
1404416
J 4 78
I've seem to have found out that as stock i'm looking at 145 - 155 Hp. Does seem like a fair bit more though.
Suppose a 0 - 60 might indicate something
Old Nov 24, 2010 | 11:53 AM
scyzoryk23's Avatar
scyzoryk23
Dyno.
Old Nov 24, 2010 | 01:01 PM
SanDiegoPaul's Avatar
SanDiegoPaul
From: San Diego - Deep Within The State of CONFUSION!
Originally Posted by scyzoryk23
Dyno.
Yep. Why guess? The dyno will tell you what's coming to the wheels and a good dyno tuner will be able to make it run better yet.
To Previous owner/s Mods
