Car "stopped" turning over - HELP
Old Apr 5, 2002 | 03:41 PM
Motor City Vette's Avatar
Motor City Vette
Default Car "stopped" turning over - HELP
Okay,
I went to start my Vette ('70 350/350) this afternoon and the first 2 times she wouldn't "catch"...turned over but didn't stay started. No big deal, it's 32 degrees, cold and I haven't started her in about a week so I figured as much that it would take a couple of cranks to get her going. The third time I went to turn the key...nothing. No lights, "clilck", fan, zero, zip, nada. So, she was turning over and then all the sudden, nothing. I checked the battery connection and that is okay. Where should I start to look at next...alternator, starter, etc.? I'm new to this "car thing" so be gentle!
Thanks!
Old Apr 5, 2002 | 03:52 PM
Black68Vette's Avatar
Black68Vette
Default Re: Car "stopped" turning over - HELP (Motor City Vette)
first thing is to just flip the key to "on" and see if the radio, headlights, etc are working,.... if not, the battery died completely
Old Apr 5, 2002 | 04:15 PM
HWY 9 - Z06's Avatar
HWY 9 - Z06
if you have proper voltage at your battery terminals but no electrical loads work, check your ground where it attaches to the frame, also check the ground from the frame to the block. a dirty or poorly connected ground can cause this.
[Modified by HWY 9 - '69, 12:16 PM 4/5/2002]
Old Apr 5, 2002 | 04:26 PM
69RPOL68's Avatar
69RPOL68
Take a look at the fusable link on the firewall near the heater box. Is it burnt? Also the connection between the fuse block halfs have been know to corrode and cause a complete power loss. :chevy
Old Apr 5, 2002 | 04:27 PM
Budman68's Avatar
Budman68
Cruise-In VII Veteran
St. Jude Donor '07
Default Re: Car "stopped" turning over - HELP (HWY 9 - '69)
Sounds like a bad connection in the starter wiring harness. Just for giggles, wiggle it a little with the ignition on and see if the interior lights come on. The plug is located at the top of you firewall by the distributor. Good luck.
Old Apr 5, 2002 | 04:35 PM
Motor City Vette
Default Re: Car "stopped" turning over - HELP (Budman78)
Thanks for all the tips (keep 'em coming!)...
I was hoping to go out and take a look at some of things you guys have suggested, but it's starting to snow like hell. Ahhh, isn't spring wonderful :p:
Old Apr 5, 2002 | 04:38 PM
verskel's Avatar
verskel
Sorry, I just couldn't pass this one up,
Title : "Car "stopped" turning over - HELP" - sounds like you needed traction control ! :jester :lol:
Yeah, check those terminals (both sides) - sounds like you have a 'loose' connection.....and the terminals might be corroded at the wires (had to redo the ones on my car just recently)
Old Apr 5, 2002 | 04:41 PM
Fevre's Avatar
Fevre
Motor City
I was going to drive my vette to work after lunch until it started snowing!:mad
Guess that's why I bought the Highrider.
BTW Left my parking lights on over the weekend and thought my battery was toast till I noticed them on while charging the battery. Doh!:bb
Old Apr 5, 2002 | 04:44 PM
Black68Vette
Yeah, I had to stop sweeping and washing the garage floor, cause I was starting to sweat so much. At least it was cooler today than yesterday, only 77 today, whew. :D :D :D
Old Apr 5, 2002 | 04:56 PM
Fevre's Avatar
Fevre
Default Re: Car "stopped" turning over - HELP (Black68Vette)
But when we have ours torn apart during the winter we aren't missing driving them!
Driven 6 months, fix em six months!
Besides, with our roads, our babies need the time off!
Old Apr 5, 2002 | 08:59 PM
dgruenke's Avatar
dgruenke
I have to agree with HWY 9 - '69. This has happened to me before. There is a ground strap that runs from the bottom of your battery compartment to the frame. Since this strap is exposed to the elements, it often corrodes. Then eventually (never gives a warning sign), the car will do exactly as you said. It will have power until you try to turn it over. A starter pulls a lot of juice. When that strap corrodes, the current cannot move through as fast as shuts everything down. I would first check that strap. Good Luck.
To Car "stopped" turning over - HELP
