Swap TO BIG BLOCK
Second - 454 is the Meanest ! :D
***side note about SBC 400's - these guys use 'steam' holes which are prone to running 'hot' & have a tendancy to blow head gaskets / ...they work well in race applications - but reliability is a ? in my mind. :chevy
However, there are some other little details - switching to a B.B. means getting the right brakets / re-tuning your front end suspension / getting a bigger radiator / different pulleys - It's not just an 'easy' swap. :eek:
But, the good news is that a mild/stock 454 puts out way more torque than the more expen$ive super-modified 350 engine..... You'll have more fun with the Big Block, too ! :cool:
Yes a BB will go fast but do your homework because if not,a hard hitting properly geared 383 or 400 will do it to you .Seen it done many times and imo building a 396 would be a waste of time and money if HP for the money is factored in
Another bit of advice would not to directly follow another forum members combination of motor parts or a Magazine Article either.
I think you should go for the 454. As long as you know that you will have to spend alot of $$ on the correct pulleys/brackets for the alternator, waterpump and p/s. I dropped $500 with http://www.corvette-paragon.com this week on those components. These items must be used as the configuration for Corvettes is much different than for a Chevelle/Camaro, etc.
The p/s pump must be for a '74 BB unit and it must be mounted low like your L-48 mouse.
The alternator must be mounted on the driver's side and up high.
The short '71-74 Corvette water pump must be used as well. I just ordered a Stewart Stage 1 pump also this week.
I know that it will be worth it in the end.... I wish that end was near so I could go driving.
You could also go aftermarket with the pulleys/brackets for around the same price but I wanted to stay stock.
I can provide you with part numbers from Paragon that I plan to use when you are ready to order........
You will have to change your username to "Mighty Rat" when you are done with your mouse motor.
Bob :cheers:
[Modified by Bob Turner, 5:40 PM 4/5/2002]
[Modified by Bob Turner, 5:41 PM 4/5/2002]
And in my opinion, they are the best engine for a vette. Almost big block power, and the light weight and handling of a smallblock. End of rant!!
