quick door panel question
Old Apr 5, 2002 | 04:53 PM
Robert Holtman's Avatar
Robert Holtman
Default quick door panel question
I managed to break my passenger side door handle, a small piece inside the door. Now you can't get out from inside the car. I'll probably replace both door handles at once so they'll look the same. What I was wondering is to take the panels off what special tools are required? I know there is something for holing that clip on the window crank. Anyone know what it's actually called and if I need a certain size? This something I can get at any parts place (Kragen, Napa) or do I have to order it special? For some strange reason passengers panic when they find out that they can't get out of my car easily. Wimps. Thanks in advance. :seeya
Old Apr 5, 2002 | 05:02 PM
Paul Borowski's Avatar
Paul Borowski
Cruise-In VI Veteran
St. Jude Donor '08-'09-'10-'11-'12
Default Re: quick door panel question (Robert Holtman)
There is a "special" tool to take that clip off with and NAPA will have it, but you can get that small "C" clip off with a very small regular blade screwdriver doing it "CAREFULLY"!!!!! :yesnod:
Old Apr 5, 2002 | 05:08 PM
Sleestak's Avatar
Sleestak
I've seen the proper tool in the HELP! section of lots of different automotive parts stores. I personally just use a flathead screwdriver.
Old Apr 5, 2002 | 09:01 PM
micks69's Avatar
micks69
Default Re: quick door panel question (Vfastboy 73)
You dont need to take the door panel off to replace the handle. The handle is held on with a phillips screw. Need to to hold the latch open to see it.
Old Apr 5, 2002 | 09:32 PM
Paul 75 L82's Avatar
Paul 75 L82
Default Re: quick door panel question (micks69)
micks is right. Pry up the handle receiver and hold it up with a flat tip screwdriver. Then you can see the phillips screw.
To quick door panel question
