are these trailing arms even safe?
Old Nov 30, 2010 | 10:56 PM
Father N Son's Avatar
Father N Son
Default are these trailing arms even safe?
http://kansascity.craigslist.org/pts/2082770938.html
Old Nov 30, 2010 | 11:05 PM
7T3C3TTZ07's Avatar
7T3C3TTZ07
Based upon the picture, it appears (to me) hard to believe that these could maintain proper toe alignment and camber under side loads. Norval has posted how to fabricate a "notch" in stock T-arms and maintain enough material around the notch to maintain the original strength if not adding strength.
Old Dec 1, 2010 | 02:15 AM
SanDiegoPaul's Avatar
SanDiegoPaul
From: San Diego - Deep Within The State of CONFUSION!
That's some scary stuff right there ....
Old Dec 1, 2010 | 07:48 AM
...Roger...'s Avatar
...Roger...
I've seen several like that but they have had a piece of steel on the inside at 90 degrees welded on.
Old Dec 1, 2010 | 08:07 AM
muskegonbrake's Avatar
muskegonbrake
Supporting Vendor
First impression is that these would not hold up. I would have to see them personally to render an opinion. Interesting idea, but I would go with an offset arm before I mess with those.
Old Dec 1, 2010 | 09:38 AM
fauxrs's Avatar
fauxrs
I sure as hell wouldnt use them
Old Dec 1, 2010 | 09:40 AM
Sigforty's Avatar
Sigforty
Cruise-In IX Veteran
For the price I would just pay extra for an offset arm. It is hard to tell if they used some good quality plate in that modification. If not plate steel I would question how well they would hold.
Old Dec 1, 2010 | 10:53 AM
mikep3's Avatar
mikep3
Default No
That being said, I saw several hundrad at the Corvettes at Carlisle for sale used that looked close to new. Dozens of rebuilt units in standard and offset with pricing at less than $400 per side.
Those look like they need just about everything.
Old Dec 1, 2010 | 11:07 AM
wcsinx's Avatar
wcsinx
Yikes
It's the rectangular "boxing" that gives the arm its strength. Without that, you'd need some pretty heavy stock welded in there to give it comparable strength and rigidity. I would not trust those.
Old Dec 1, 2010 | 12:13 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Look at it this way...do you want to take the chance of finding out whether they're safe?
Old Dec 1, 2010 | 12:36 PM
Corey_68's Avatar
Corey_68
Considering I've thrown away some in better condition....NO
Old Dec 1, 2010 | 12:57 PM
larryg3's Avatar
larryg3
you are kidding right.........
Old Dec 1, 2010 | 12:58 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
Even if the thin part was billet steel I would put them on
Old Dec 1, 2010 | 05:48 PM
Neptune75's Avatar
Neptune75
um.. they look legit to me. LMFAO...
Old Dec 1, 2010 | 11:10 PM
Imo Apita's Avatar
Imo Apita
OLD SHOOL
Says enough.....I vote for NO....run away.....
Old Dec 2, 2010 | 12:06 AM
myoriginal77's Avatar
myoriginal77
yikes !
To are these trailing arms even safe?
