Hood Pin Set-Up
Old Nov 30, 2010 | 11:45 PM
glackore's Avatar
glackore
Default Hood Pin Set-Up
I've got an aftermarket L88 hood that I would like to pin down in the rear versus using the stock set-up. (cable, pins and latches). I like the road-race look. Does anyone know if there is a manufacturer of brackets and pins for the C3s? Thanks!
Old Dec 1, 2010 | 12:16 AM
eagle275's Avatar
eagle275
Default link on forum
http://www.hoodpins.net/
http://forums.corvetteforum.com/c3-t...and-stops.html
Old Dec 1, 2010 | 10:37 PM
glackore's Avatar
glackore
Thx eagle 275. I found this link, now I need to talk with them. I'd like to know if they have brackets the pins mount to or if I have to fabricate them myself.
Gary
Old Dec 1, 2010 | 10:40 PM
eagle275's Avatar
eagle275
sure thing. Be sure to show some pics! Good luck with that.
Old Dec 6, 2010 | 09:38 PM
Grumpy 427's Avatar
Grumpy 427
I would be interested in this too. Can you post the link at least?
Old Dec 7, 2010 | 05:46 AM
aworks's Avatar
aworks
You use the stock brackets. Just screw the hood pins in place of the male pins. Depending on how long your pins are you may have the weld a nut on top of the stock brackets first. You can see the left one in this pic.
Old Dec 7, 2010 | 08:00 AM
Grumpy 427's Avatar
Grumpy 427
Very nice engine bay, looks very clean and un cluttered.
Old Dec 7, 2010 | 08:34 AM
lvrpool32's Avatar
lvrpool32
I used the stock mounts aswell, unscrew the factory location pins, and install the hood pins (just make sure the hood pins are 1/2")
Nick
Old Dec 7, 2010 | 10:45 AM
glackore's Avatar
glackore
Thanks guys! I'll probably look to relocate my RH bracket so the pins are in alignment on the hood. This is a January project - along with many others. As soon as I have pics I will post them
To Hood Pin Set-Up
