Air filter base gasket, hate it
Old Dec 1, 2010 | 05:51 PM
chevymans 77's Avatar
chevymans 77
St. Jude Donor '05-'06,'11,'13-'14,'16,'18,'19,'24, '25
Default Air filter base gasket, hate it
I have never liked the gasket that the filter base sits on. The base has a thin sharp edge and the gasket never fits it right.
So I set out to make it better, I wanted a better seal and the base to fit snug.
I took a piece of small vacuum hose and split it were it would fit over the sharp edge of the filter base. Then I cut it to length and slid it onto the filter base. The fit is snug and the base does not move around like before.
Here is a couple pics of the install:
Neal
Old Dec 1, 2010 | 06:21 PM
Will's'74VetteL-82's Avatar
Will's'74VetteL-82
Nice, it looks good!
Will
Old Dec 1, 2010 | 06:54 PM
Paul L's Avatar
Paul L
The base properly seated on the stock gasket does not "move around." I do not understand your problem.
Old Dec 1, 2010 | 07:35 PM
JimT's Avatar
JimT
Great idea - I like it. I'm starting mine in the morning.
Thanks!
Old Dec 1, 2010 | 07:37 PM
daanbc's Avatar
daanbc
St. Jude Donor '12
Mine does not move either. Maybe its worn? Is it an aftermarket?
Old Dec 1, 2010 | 07:53 PM
mar's Avatar
mar
Why would it 'move around'?
Old Dec 1, 2010 | 11:03 PM
chevymans 77
Yes its an aftermarket drop base,
The factory housing will not have this issue
Old Dec 2, 2010 | 12:44 PM
toddalin's Avatar
toddalin
But that doesn't mean that the factory housing cannot be improved upon.
The rolled edge at the carb creates a "dead zone" that can be alleviated with a piece of low voltage malibu wire, or even a rubber O-ring. Car Craft found 10 hp on one of their truck builds by addressing this area in a similar vein.
Old Dec 2, 2010 | 10:26 PM
chevymans 77
Looks good toddlin, never thought of the effects of filling in the void area.
Neal
To Air filter base gasket, hate it
