Oil Leak Question
Old Dec 2, 2010 | 03:05 PM
Kevins77's Avatar
Kevins77
Default Oil Leak Question
I have an oil leak that I have been troubleshooting thats just leaving me scratching my head. I cannot seem to find where it is coming from.
It leaks just a bit directly under the bellhousing of the transmission. I thought it was coming from the rear main, but I noticed it is actually pooling up on the TOP of the bell housing on the drivers side just a little more towards the center of the car than the pressure sender. Its pooling up a little during driving then running off just enough to make a circle under the car.
Anyways, ive checked and double checked the valve covers, Ive pulled the sender and teffloned it good. I have taken and wiped a white cloth across the back of the intake in that area after driving and found almost nothing. Basically I have no idea where its coming from.
Anyone else ran into this and what did it end up being?
Old Dec 2, 2010 | 03:12 PM
Vette5.5's Avatar
Vette5.5
You can wipe everything up, and put some UV tracer dye in the crankcase. After some mile's, scan around with a UV light and should be easy to find.
Old Dec 2, 2010 | 03:52 PM
JimT's Avatar
JimT
Check around the base of the distributor.
Old Dec 2, 2010 | 05:05 PM
redman76's Avatar
redman76
St. Jude Donor '09
That was the only way I could track mine down. You can get in different colors too to help differentiate between PS, Tranny, engine, whatever. You should be able to get at any auto parts store like AZ.
Old Dec 2, 2010 | 08:24 PM
TimAT's Avatar
TimAT
Wash it down with alcohol or something that air dries, then dust it with baby powder. The oil will track in the baby powder like a neon sign. The UV dye works well too, but baby powder and alcohol are really cheap.
Old Dec 3, 2010 | 12:18 AM
71406's Avatar
71406
I had some oil coming from the mounting base of the distrinutor. Installed new gasket and still leaked. Tried another gasket but this time put white lithium grease on both sides before installing. Did the trick. Hope you find where your leak is coming from.
To Oil Leak Question
